put my engine back in and these parts are still available
wheres the location these are have to be fitted?
Regards
Gerald
specter has attached the following image:
| Author | Subject: Parts Location |
specter
Regular Location: Graz Registered: 05 Apr 2011 Posts: 103 Status: Offline |
Hey thereput my engine back in and these parts are still available wheres the location these are have to be fitted? Regards Gerald specter has attached the following image: |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
specter wrote: Hey there put my engine back in and these parts are still available wheres the location these are have to be fitted? Regards Gerald The Part on the right is part of your gear box mount, not sure about the one on the left though.... ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
The bracket looks like one of those that bolts to the inlet manifold. As Jeffers said the other part needs to go over the gearbox mount stud before you put the rubber mount on________________________________________ Ryan |
mechanical_repairs
As above the bracket is for the inlet manifold to the right hand side and mounts underneath, the other is a sleeve that goes on the stud for the gearbox mount, once bolted up it sits inside the rubber bush.Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
stan_306gti6
Moved to Engines. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
