Author Subject: inlet manifold
boost
anyone know what difference it makes to port and polis an inlet mani ? n anyone know how to go about it is it basicly 20mins with a dremmell ?
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 13th Oct 2012 at 21:05
You can have a go with a Dremmel if you want!LOL
But people that know what they are doing would spend a few good hours on itThumbs up
You can smooth out casting marks etc,but in reality it would make little difference,you really need someone that knows what they are doing working on it to see any real gainsYes
Posted 13th Oct 2012 at 21:26
Russian guy is the guy to talk to. He has done this and plenty more mods to his rallye and it goes like stink!!
Posted 13th Oct 2012 at 21:38
You can't port it without cutting it open, if you don't fancy that forget it. If you do cut it open I'll happily weld it closed for you.
Posted 13th Oct 2012 at 21:44
boost
so if its done properly u can see some real good results from it ? cheers lads
fatlapit
Just match it to ya head and same with exhaust manifold.
Posted 13th Oct 2012 at 21:49
boost
the ports smaller on the inlet like ? or will i have to do the head too ?
Posted 13th Oct 2012 at 21:50
gti6girl
We have one on management and its slightly quicker than when it was on bodies
Posted 13th Oct 2012 at 22:28
boost
do i jave to change the management system too if i port the mani like ?
Posted 13th Oct 2012 at 22:35
The smoother the better
Posted 13th Oct 2012 at 22:37
gti6girl
Yeah they don't work to well on standard management
Posted 13th Oct 2012 at 22:52
gti6girl
I'm actually selling the manifold, throttle body and loom and ecu
Posted 13th Oct 2012 at 22:54
Rich E Forum Admin
To properly port and polish an inlet manifold you will need to cut it open and weld it shut again once you're done. Good luck doing all of that in 20 minutes a Dremel.
On a standard engine you will lose power and torque. There's potential for increasing top end power but only with cams and an ECU remap to suit.
Posted 13th Oct 2012 at 23:02
boost
how much for the whole lot n thanks people youve been helpful Smile
Posted 13th Oct 2012 at 23:15
gilesy
Have you heard of the sand method?
Posted 13th Oct 2012 at 23:22
