Author Subject: 2.0 various mi16 parts and 205 gti parts
yippeekayay
205 Almost new hardly used 4 branch DES developments 2.0 ( cast iron block) 4 branch heat wrapped Manifold to down pipe. £225 ono (wont fit gti6 engine)
quality lovely sounding and great fitting system to suit 4 branch to fit 205 gti with mi16 (2.0). £250 ono will fit gti6 with mods or the full system£400
2.0 mi 16 big valve and ported head £200 to clear.
2.0 mi 16/S16 std head low miles ( sub 5k) £250 ( less cams)
2.0 mi 16 S16 catcam inlet cam less than 3k use ( £150) or will do with head £300)
2.0 Mi 16/S16 bottom end. in very very good condition. less than 5k £400
will do the S16 Mi16 bottom end and head complete for £600 ono ( engine has head removed for inspection).
mocal 13 row oil kits x2 and pipes hardly used 1 nearly new with oil filter housings £110 ea.
set of red mi16 205 samco water hoses £85 as new.
set of 8v 1.9 gti samco blue hoses £85 in very good order
std 1.9 8v 205/309 gti machined head, aligned and pressure tested and rebuilt with new stem seals... £150
rebuilt 8v 205 gti 1600 bottom end £100.
205 /309 turbo technics 5th injector control box x2 £50 ea. turbo technics wiring loom £100
205 / 309 TT ecu £50
205 / 309 TT AFM £50
205 / 309 TT distributor rare specially adapted by turbo technics £75
MF2 5th injector 2d and 3d mappable cost £425 new looking for offers on £200 with loom and 5th injector.
omex 600 loom connector mated to loom from a turbo charged rover 620ti, can be adapted to make pug loom. £50
also Standard 1,9 gti fuel pump adapted to feed carbed engines great working order, basically used in conjunction with a forward after market fuel pump but pumps the fuel out of the tank offers on £60
x box "yippeekayaymofo"
Posted 9th Oct 2012 at 17:08
peugeot96
What kind of Catcam?
Who has done the big valve head?
Posted 9th Oct 2012 at 18:17
yippeekayay
I bought the car complete with the nearly new engine with Catcam inlet cam fitted Brand new. That's all I can tell you unless I strip the cam out at the weekend. can send pictures then.
The Big valve head also came as an engine package and have no proof of who built it hence £200 not £450 -£500 but the heads definitely been worked.
Posted 9th Oct 2012 at 18:29
peugeot96
Photos of cams and head?
Posted 9th Oct 2012 at 19:22
yippeekayay
will do at the weekend
Posted 9th Oct 2012 at 19:27
peugeot96
Ok
Do you know the Compression hight and cylinder head volume on the xu10j4 engine?
Posted 9th Oct 2012 at 22:29
yippeekayay
no sorry....
Posted 9th Oct 2012 at 22:37
