Author Subject: Temp gauge next to the clock
jonnyvandijk
The temperature gauge has been messing me about for ages, now the cars coming out of storage I want to sort it.
When ignition is turned on, it will come on, displaying an outside temperature but showing it as 30 degrees.
Then it will hunt all the way down to -30 degrees skipping three degrees at a time, then finally it displays --
Anyone had this before? I've put my display into a different car and it worked fine so not that, also swapped the sensor and that worked on the other car. Does that just leave wiring? Or is there something else?
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 9th Oct 2012 at 14:22
Niall
either broken wires in the passenger door or needs a new sensor in the wing mirror
Posted 9th Oct 2012 at 21:34
rich306
Thats interesting Wink
I'm thinking it could be the actual unit itself playing up, tried swapping it with one you know works?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 9th Oct 2012 at 21:58
jonnyvandijk
I've tried a working display and sensor to no avail.
Could he the wiring yes, I will look into it. Niall, is that based on experience or a guess?
Posted 9th Oct 2012 at 22:52
jonnyvandijk
Or am I going to have to put a Rallye clock in?
Posted 9th Oct 2012 at 22:54
6waysforward
Change the outside temp sensor in the passenger wing mirror.
5 min job to do.
This cured mine Smile
Posted 10th Oct 2012 at 00:54
jonnyvandijk
Did yours do the same hunting thing I described?
Posted 10th Oct 2012 at 09:20
I would imagine it's the sensor in the mirror to be honest. Yes
Posted 10th Oct 2012 at 15:10
jonnyvandijk
As I said I changed the sensor with a known working one and it was still broken. I put the sensor from my car into another one and it worked.
Sh*t the bed is anyone reading my posts??! Laugh
Thanks for the help though, I think it has got to be wiring even though the wires look fine.
Posted 10th Oct 2012 at 15:41
Doh
Must stop skim reading...LOL
If the display works and the sensor has been swapped for another good known working one, then I'm with you on the fact that you have a broken wire on that part of the loom. Yes
Best thing to do is to check the continuity on the loom and see which wire doesn't bell out. Wink
Posted 10th Oct 2012 at 19:20
Have you tried changing the sensor for one you know works?
Posted 10th Oct 2012 at 19:36
Dry LOL
Posted 10th Oct 2012 at 20:14
Niall
Thats based on the fact that theres only 3 components to it. Sensor, wiring and clock and the clock is literally just a display for it.
Posted 10th Oct 2012 at 20:22
