displaying posts 1 to 25 of 31
Author Subject: What is needed and why
Matt_rallye
Can come give me some insight into throttle bodies. Been looking around an cant find a very good list of parts and descriptions.
Basically if I was too build up my own set of bodies what would I need, looking at r1 bike bodies or jenveys.
All what management is best to go for? When it comes to management I have no idea
Posted 7th Oct 2012 at 09:04
You will need;
Bodies
Some way to connect them (bike bodies don't usually have a suitable flange to this means rubber hoses and clips)
An inlet manifold (usually a cut up std mani with pipes pushed on)
Air temp sensor
Throttle pot (and some way of mounting it)
Throttle linkage (a modified curburettor one or something)
Filters (individual or better still a backplate and sausage/some filter)
Trumpets, full radius if you can get them.
Ecu. If you can get the car up to Chip Wizards you can keep the std one, failing that speak to your mapper of choice and ask what his favoured ecu is as they all have their favourites. Unless you are mapping it yourself they are all much the same.
You may need a 4 way coil pack and leads depending on ecu if you decide to go aftermarket.
Posted 7th Oct 2012 at 10:10
Personally I'd go with an off the shelf kit and save myself the hassle, I'd not buy the Jenvey manifold this time around though.
If you're determined to go for bike bodies I'd get the Colin Satchell setup with inlet mani and trumpets from him as well.
Posted 7th Oct 2012 at 10:14
Matt_rallye
Cheers mate. I may come down your way soon. I now have the money for that stuff we talked about previously. Also check yours out Razz
Also what's the best bodies to go for? I'm presuming everyone will say jenveys?
I have had a read through yannis thread for the r1s with just the r1s and remap would I see much gain? Or is it best to cams, port and polish at the same time?
Posted 7th Oct 2012 at 10:15
You only want to pay for one session on the rollers, so it's best to plan out all the mods you want and do them all together, otherwise you pay out every time you change something.
Posted 7th Oct 2012 at 10:19
Matt_rallye
Im looking at off the shelf stuff tbh, dot know if I'd hve the patience to mess around with a home brew kit.
But off the shelf are looking quite expensive. Unless I'm missing something? Also second hand don't seem to come up that cheap either. Seems a lot of money for little gain
Posted 7th Oct 2012 at 10:22
It changes the way the car drives and feels and enhances the experience. On paper it's not s big gain but having had them both I miss them more than SC. They also open the door for other mods to work better, cams and exhausts will give bigger gains when coupled to a well matched inlet system. Plus the increased control from a tailored remap gets the most out of the system as a whole.
Posted 7th Oct 2012 at 10:33
Matt_rallye
Ahhh right, starting to understand a little more. Do at all in brand new how much would I be looking at?
Everything brand new from Jenvey looks pricey. Think I may have to buy things in stages.
What manifold will be best for Jenvey bodies? Jenvey one or longmans?
Posted 7th Oct 2012 at 11:00
Jenvey/Longmans is the same thing. They get a bad press on here, so you really want a Satchell inlet.
Cost wise it's a lot, I got a good deal by talking to Simon at Jenvey and getting him to sell me the stuff direct.
Posted 7th Oct 2012 at 11:09
Matt_rallye
That makes sense them being the company. Facepalm.
I've seen the satchel manifolds they look pretty good.
I did think about trying to chat to someone at Jenvey seeing if some sort of discounted price could be sorted. Don't know if you don't try Wink
Daveyboy if I were too get all the parts I need. Could you give me a hand sorting it? As you sound like you have experience with bodies Smile
Posted 7th Oct 2012 at 11:15
demondriverdan
Out of interest, where the hell do you find Colin? Info seems to be few and far between!
Rallye Race Car
Posted 7th Oct 2012 at 11:21
Matt_rallye
Was just about to say this, all I can find is threads?
Also what size trumpets to go for? I guess there is a standard diameter? But what lenghth and does that make a difference?
Going to end up buying parts separately
Satchell manifold with Jenvey bodies (45mm is that right?)
90mm trumpets(seen a few with these, guess its 45mm diameter for the bodies and then 90mm in length?)
Posted 7th Oct 2012 at 11:26
He's a bit off the radar, I can get you a number on Monday.
Posted 7th Oct 2012 at 11:28
I'm sure I can give you a hand. 45s are good on a standard or lightly modified engine, 90mm trumpets are a popular choice for a reasonable spread of torque.
Posted 7th Oct 2012 at 11:36
Speak to miles, he's doing satchell dcoe pattern inlets plus everything else you need, inc fitting and mapping if required.
Posted 7th Oct 2012 at 11:48
Matt_rallye
So 90mm would be for more modified like cams?
Hopefully will be running cams with the bodies so may go for 90mm trumpets. With the trumpets is there a particular brand to go for?
Posted 7th Oct 2012 at 11:56
Matt_rallye
Posted 7th Oct 2012 at 12:13
I meant 45mm bodies fella, 45s and 90mm trumpets is a good spec.
Posted 7th Oct 2012 at 12:18
Matt_rallye
45mm bodies ahh good stuff. Are the bodies universal or best to get the 306 ones from Jenvey
Posted 7th Oct 2012 at 12:31
The Jenvey 45s are not car specific, just get the paired DCOE style ones not individuals. You really are best speaking direct to Jenvey as they can talk you through all the pros and cons.
Posted 7th Oct 2012 at 13:23
Did you miss my post?
Posted 7th Oct 2012 at 16:21
Matt_rallye
Nope I didn't, have messages him! Big grin
Posted 7th Oct 2012 at 17:26
vts_tibi
My biggest concer about the throttle body conversion is the intake air temperature. Most guys simply put an air filter on the end of the trumpets and leave it as it is, so the engine will suck in hot air from under the bonnet.
Is there any clever solution for this?
The best would be something like this:
But AFAIK such solutions need a lowered rad ain't?
OR
We could fabricate an airbox over the trumpets, just like the Pipercross airboxes:
But they are quite pricey at 180GBP Sad , so it is time for a bit of DIY.
Could we mate such airboxes to a BMC CDA filter - I know it's technically possible but won't it affect performance?
VTS
best 60' : 2.272
Team Trackday™
Posted 7th Oct 2012 at 18:18
woody.
^^^^^^ I've also wondered this Dunno
Posted 7th Oct 2012 at 18:31
As long as the filter itself was large enough capacity then no, no problem.
Posted 8th Oct 2012 at 11:26
