Author Subject: Clutch judder
tony1991
Well after having fly wheel re faced got the garage to fit new clutch and new fly wheel. Still had a slight cluch judder but getting worse. Spoke with a friend and he said worst case been bottom pulley gone, when I brought the engine it had under gone a refurb on bottom end 2k before, my personal opinion not been a mechanic is the fitting of new clutch/ fly wheel was not correct ie bolts at wrong toque
Can any body shed any light on this
Thanks tony
Posted 24th Sep 2012 at 21:47
jeffers Forum Admin
Moved to correct section.
Team Running Engine again!
Team Negative Camber!
Posted 24th Sep 2012 at 21:48
tony1991
Thanks just realised after that
Posted 24th Sep 2012 at 21:50
Can't see the bottom pulley causing it!Unsure
as you say,the clutch cover has prob not been bolted down evenlyThumbs down
Posted 25th Sep 2012 at 08:16
Did they fit a new clutch cable and clutch shaft bushes.
I doubt very much that incorrect torque would cause it unless the bolts were loose.
Have the engine mounts been replaced?
Posted 25th Sep 2012 at 08:31
incorrect torque would not,but bolting down unevenly can.
Thinking again,could also be the metal part the release bearing slides on,mine was pretty rusty and the bearing would not slide nicely on it,needs cleaning up with emery clothThumbs up
Posted 25th Sep 2012 at 09:27
tony1991
I asked my friend if sticky cable coud cause this an he said not. My clutch pedal sticks a bit which i fort could be the problem and I read about the bush yesterday il try cable first, but I'm getting a light weight fly wheel so if that don't work il strip it down and clean an sort everything along with another new cluch
Posted 25th Sep 2012 at 11:42
I'm slightly confused by this. Did you have the garage fit a "new" flywheel or the one you had re-faced?
If it was the re-faced unit, then it's quite possible the flywheel is now slightly out of balance although they should have spun it up and re-balanced it when they took the material off the front. Yes
Alternatively, it could well be the clutch pressure plate which hasn't been tightened in the correct pattern and therefore is causing judder now. Wink
Posted 25th Sep 2012 at 13:58
Was the friction plate in the pressure plate skimmed too? As the judder could be caused by uneven wear there.
Posted 25th Sep 2012 at 14:17
tony1991
I got the garage to fit my refaced one of my old engine ( was fine but got it refaced anyway) then they fitted my cluch I had been running for a week with clutch judder, which was worse so put a new clutch kit on, was not perfect but very slight judder but now it is getting terrible
Today I drove it an now have knocking noise as well from engine
Posted 25th Sep 2012 at 22:13
Bottom end completely shagged by the sound of it.
Posted 25th Sep 2012 at 22:18
tony1991
I think I agree unfortunately
When I brought he engine apparently only had bottom end refurberd 2k before bit gutted not done many miles t all
Posted 25th Sep 2012 at 22:27
Gutted for you, any chance of comeback?
Posted 25th Sep 2012 at 22:42
tony1991
Well I got it of a member on here, when I picked it up I fort I had a good engine might go ack to sorting head out on my old engine
Posted 25th Sep 2012 at 22:47
Thats a bummer, sounds like they knew about it though as you don't usually pay out to refurb an engine only to sell it right away...
Posted 26th Sep 2012 at 09:19
It most certainly shouldn't be the engine unless it has been run dry, it had a brand new clutch when it was built and fitted in the original car and had no issues at all from what I know of it, as you'd expect from a new clutch + cable + bushes, its never run since it was in that car afaik.
The previous owner can never make his fecking mind up about what he wants to build, he's gone from a 2140cc bodied 205 back to a 1905 carbed 8 valve in the space of 18 months Laugh my ass off he never used this engine, nor did the guy he bought it off.
It SHOULD be a good lump for years to come, however I never actually heard it run LOL
Posted 26th Sep 2012 at 11:22
This needs a bit more looking into methinks.
Posted 26th Sep 2012 at 16:17
Agreed, something certainly doesn't sound right, especially if the bottom end is now knocking itself to pieces when the issue started out as clutch judder...Crazy
Posted 26th Sep 2012 at 20:36
tony1991
I have the chance to get back to the garage I not really sure on there work tbh but they should look after me as I do a lot of work for the garage so as I'm not a mechanic im tuna get it back in at weekend I will keep you up dated, also burning abit of oil not majorly but take it for good drive you can smell it
Il let the garage have a look not looking forward to the price tho
Posted 26th Sep 2012 at 22:15
If its knocking dont even fire it up.
Posted 26th Sep 2012 at 22:18
Damage is already done by the sound of it.
Posted 26th Sep 2012 at 22:40
