Author Subject: sensors
t-rex
Hi does anybody have a drawing ect of the sensors,the position of
Posted 23rd Sep 2012 at 19:42
fatlapit
Which ones?
Posted 23rd Sep 2012 at 20:01
t-rex
crank and cam
Posted 23rd Sep 2012 at 20:02
Cam sensor is right in front of you on left as you look from front,blue sensor with a three pin plug.
Crank sensor is on top of bell housing,picks up signal off the flywheel.look down below thermostat housing.Thumbs up
Posted 23rd Sep 2012 at 20:06
t-rex
cheers boysThumbs up
Posted 24th Sep 2012 at 10:59
Useful pictures for reference:
http://forum.205gtidrivers.com/index.php?showtopic=99387
  • Posted 24th Sep 2012 at 11:18
    t-rex
    Brilliant thanks very much,trying to figure out why the bloody thing wont start, so need to check ALL the sensors.Shock
    Posted 24th Sep 2012 at 19:46
    Whats the story with it not starting?
    Recent work done/problems/parts replaced etcWink
    Posted 24th Sep 2012 at 21:18
    t-rex
    Lets start at the begining,it's an s16, sent ecu to Carl to be unlocked coz the immobiliser packed up (key pad type ) still wouldn't start, bought a double relay BITRON 240107 still nowt,no pump prime,no spark,no injection,so now looking for another reason, that's the story so far.Sad
    Posted 24th Sep 2012 at 23:47
    The crank and cam sensors will not affect the fuel pump priming. The fuel pump would still prime even if the immobiliser was still on, there just wouldn't be an ignition pulse for the coils. Wink
    Posted 25th Sep 2012 at 15:38
    I know you said you have replaced the double relay behind the ECU box, however have you actually checked those relays are being fed power? Dunno
    Posted 25th Sep 2012 at 15:39
    will the inertia switch stop it priming / sparking etc?
    Posted 25th Sep 2012 at 15:46
    t-rex
    To answer your query Stan,i'm a wagon driver on distance work so i get approx,one and a half days off so it takes along time to get things sorted, but iwill dig my multimeter out and check this weekend.Unsure
    Posted 25th Sep 2012 at 20:16
