Author Subject: Mechanical vs Hydraulic Cams
speedo306
What type of cams come on the gti6? What's the difference between the mechanical vs the hydraulic?
RJ
Posted 21st Sep 2012 at 04:11
The standard cams are designed for hydraulic lifters.
Posted 21st Sep 2012 at 07:41
pete_rallye
Generally mechanical cams have a lesser down slope so the loads on the valves aren't as harsh. The hydraulic buckets act like a little shock, so they absorb some of the impact of the valves closing, but this can also cause erratic valve behavior at higher rpm, hence why the change to mechanical buckets is required. I imagine the cams themselves aren't too dissimilar, its more like the operating conditions that determine whether you should change to mechanical buckets or not.
Lap of the 'ring
Posted 21st Sep 2012 at 07:47
Usually you can't use hydraulics on solid or vice versa.
Posted 21st Sep 2012 at 10:36
Really?
As my rev limit is 8k, I was told if I wanted to up that and regularly go over 8k then I would need to change to solid tappets, still utilising the standard cams which have been designed for hydraulics...Dunno
Posted 21st Sep 2012 at 10:59
speedo306
Where can I get solid tappets? and do these look like Thumbs up
RJ
Posted 21st Sep 2012 at 11:05
solid tappet shop Thumbs up
http://www.pipercams.co.uk/pipercams/www/index.php
Posted 21st Sep 2012 at 11:08
Why do you feel you need them?
Posted 21st Sep 2012 at 11:35
speedo306
i need the 6 to go faster i do not want to super charge or turbo
RJ
Posted 21st Sep 2012 at 11:43
Ah. I suspect you're about to hear some people's opinions on this statement.
Posted 21st Sep 2012 at 11:46
How about a different engine then.
  • Posted 21st Sep 2012 at 11:50
    speedo306
    just looking for about 200+ bhp
    RJ
    Posted 21st Sep 2012 at 11:52
    speedo306
    like
    RJ
    Posted 21st Sep 2012 at 11:53
    What cams are you looking at getting? I ask because as mentioned they are designed specifically to run with one type of lifter or the other. You realise there will be a significant extra cost involved in buying then machining shims to fit to solid lifters to give the exact valve clearances required? (Something that is done automatically with hydraulic lifters)
    Posted 21st Sep 2012 at 11:57
    throttle bodies, modified/forged pistons, PH2's or BP285H's will get you near 200 (not sure if 285H's will go in a modified std piston though...)
    Posted 21st Sep 2012 at 12:01
    To get 200bhp+ you don't need to change the lifters...cams and throttle bodies with aftermarket management will do it. Thumbs up
    Posted 21st Sep 2012 at 16:45
    Yes, but depends on the cams he buys, if he already has a solid lifter spec cam in mind then he may need to change his plans.
    Posted 21st Sep 2012 at 17:01
    a solid lifter cam will more often than not have too much lift for std or even modified pistons.
    Posted 21st Sep 2012 at 17:13
    ^ I know, but I think the OP needs to sit down and plan his build so the parts compliment each other and are compatible. He's going to open a whole can of worms if he just runs out and buys cams, buckets, shims and pulleys from four different places and none of its going to help if he doesn't start with a plan. Sort the bottom end first to prepare it for better cams with higher lift. Or else it will be a wasted effort.
    Posted 21st Sep 2012 at 18:59
    To be fair Jim, he could buy a set of PT81's, add some throttle bodies and reach the desired target figure. Yes
    That way, there would be no need to mess with the bottom end or the lifters. Wink
    Posted 21st Sep 2012 at 19:06
    We all know how close the valves run on standard cams, add lift and duration without doing the necessary bottom end work is at best going to rob you of power, (retarded cams to clear pistons don't make max power) or at worse smash the valves. I personally wouldn't bother messing with cams on a standard bottom end, it's just not worth the risk. Just my tuppence worth though.
    Posted 21st Sep 2012 at 19:14
    You have a point. Yes
    If the OP is looking at out and out max power he can achieve then machined pistons at the very least are what is going to be required if a cam change is on the cards. Wink
    Posted 21st Sep 2012 at 19:21
