Author Subject: Driveshaft ring
rich306
Right, just went to two motor factors asking about getting the ring that sits on the driveshaft securing the outer head, as mine has snapped in two.
Since I am struggling to get hold of this I came up with an idea and wanted to run it by you guys.
Would I be able to cut down and modify a keyring that is the same diameter to fit?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 18th Sep 2012 at 09:46
GTI-6
errrrrrrHmm Well. It isn't going to rust Big grin
To do the job intended it's got to be able to compress slightly and have the same spring value to keep the shaft in.
If it were me, I'd consider it. Check the thickness with a set of calipers, as you dont wanna push it in and find it's stuck Cry
If you get the right length, thickness and shape, then I guess you could.
Weird question though. +1 for that.
Love thy 6
Posted 18th Sep 2012 at 10:01
you'll get them from Peugeot, or in a gkn driveshaft boot kit.
good luck with pug though, took me some time to find it on servicebox, if I have time and remember I'll find it later....
Posted 18th Sep 2012 at 11:14
rich306
Cheers guys, trouble is I know what pug are like, I'll give them a ring now and see if they have it in stock.
I know what their ordering in skills are like and they are crap.
- Top Tip!!!
Posted 18th Sep 2012 at 11:15
rich306
I might need that part no. Peugeot have no idea what I'm after. They seem to reckon I am talking about an R shaped clip :S
- Top Tip!!!
Posted 18th Sep 2012 at 11:28
you need to check its the right size...
3294 06
DR SHF SNAP-RG
24,36 X 27,36 - 1,5
Posted 18th Sep 2012 at 13:33
They think you mean the R clip which goes through the end of the shaft to keep the nut from working loose.
  • Posted 18th Sep 2012 at 13:35
    rich306
    Right, well i went there in the end, they have the C shaped clip but.... i'd have to buy the kit which costs a lovely £38 which; for just a clips purpose is silly. I'm going to try this keyring method and see whether it works.
    - Top Tip!!!
    Posted 18th Sep 2012 at 18:11
    fatlapit
    ring up a drive shaft company
    Posted 18th Sep 2012 at 18:14
    did you not quote the part number I gave you?
    FML.
    Posted 18th Sep 2012 at 18:33
    I got one from a local Landrover parts placeWink
    Just took the old one in and they matched it upThumbs up
    Posted 18th Sep 2012 at 20:40
    rich306
    FML.
    Unsure I didn't spot your post buddy, i was using my iPHone to post on the forum at the time.
    Thanks for searching though buddy Smile I'm sorry i didn't use it, but it is really really appreciated.
    I've now fitted it all after using the keyring. i made sure it was spot on with the old one; which worked and saved some money in the process!
    - Top Tip!!!
    Posted 18th Sep 2012 at 21:21
