Author Subject: Fuel Pump Problems
tom275
Car broke down last night, seems to be having problems with fueling, coughing and spluttering not picking up revs just stalling. RAC man seems to agree its the fuel pump and we tested the coilpack etc. Strangely the problem first came about going round a fast left hand bend, the problem then became worse going round the exact same corner! So obviously the fuel pump can't handle the extra G-Force put on it under heavy cornering.
Would you guys agree with the diagnosis, anything else I should try?
Anyway, are all petrol fuel pumps on the 306 the same or will I need one specifically from a GTI?
Tom
Posted 17th Sep 2012 at 10:34
What colour is your car?
Spotted a China '6 knocking about the other evening.
Funnily enough it was in the petrol station, so may have been you LOL
  • Posted 17th Sep 2012 at 10:38
    tom275
    Ha it is china, with black wheels. x reg
    Which fuel station?
    Don't suppose you have a spare fuel pump :p
    Posted 17th Sep 2012 at 10:42
    When was the last time the fuel filter was changed?
    Posted 17th Sep 2012 at 10:44
    Yeah that'll be you then. Was Saturday afternoon/eve. Sainsbury's.
    Unfortunately not. Will have a Xsara VTS one shortly, but I imagine the housing is probably different. Worth a question I suppose.
  • Posted 17th Sep 2012 at 10:45
    c_j_m
    Got a spare here, removed it yesterday from a running 6
    Posted 17th Sep 2012 at 11:08
    tom275
    I couldn't say when it was last changed tbh, is it likely to cause such big problems?
    Don't think it was me actually, must be another lurking around! Was it dropped about 60mm? I've seen a Dturbo in China with Black wheels around running a silly ride height.
    The internet seems to think the fuel pump is the same in the xsara actually.
    How much do you want for it CJM?
    Posted 17th Sep 2012 at 12:12
    I didn't pay a huge amount of notice. Saw a China ph3 as I passed.
    Well if it is the same and your in no immediate rush then it's yours for a tenner.
  • Posted 17th Sep 2012 at 12:43
    Yes, if it is clogged and not allowing sufficient fuel flow.
    It probably isn't the cause in this case, but it is worth a check especially as you don't know when it was changed. Yes
    Posted 17th Sep 2012 at 14:11
    c_j_m
    Looking for £20 collected from andover.
    Posted 17th Sep 2012 at 14:43
    tom275
    Posted?
    Posted 17th Sep 2012 at 18:16
    speedo306
    I am waiting on your address and contact so that I can arrange my couriers to collect the parts I purchased from you.
    RJ
    Posted 17th Sep 2012 at 23:33
    c_j_m
    Can do £25 posted, can also get it sent tomorrow if needs be.
    PM'd with address etc.
    Posted 18th Sep 2012 at 00:58
    teo79
    Check your battery is properly secure and connections are tight it could be your battery is moving about bringing the terminals loose on the bends it happened to me recently
    tjones
    Posted 18th Sep 2012 at 06:00
    tom275
    Well changed the fuel pump and it hasn't made any difference. So it must be a fuel pressure problem. Anyone get any ideas? I'm gona start checking all the fuel lines next. Could it be the fuel pressure regulator?
    Posted 18th Sep 2012 at 19:46
    Sounds like a bad earth too me ?
    Check battery terminals then check the earths on the gear box Yes
    Posted 18th Sep 2012 at 19:54
    Is this a constant problem or just on heavy cornering?
    Did you change the fuel filter in the end? I've got a few bits and bobs here you can try as an elimination exercise if you like.
  • Posted 18th Sep 2012 at 20:04
    This is the order I would look at things in:
    Check battery terminals for tightness and corrosion.
    Check all earths to make sure they are tight and corrosion free.
    Change the fuel filter.
    Let us know how you get on. Thumbs up
    Posted 19th Sep 2012 at 07:26
    tom275
    I hadn't even considered it could be electrical, but sure enough it seems the battery box has broken and the battery shifted. So that would explain the left hand cornering issue.
    So if I disconnect and reconnect the battery the car will drive ok again, but coughs and splutters. However after driving it a bit last night it seems to be absolutely fine again!
    Its been having starting problems recently aswell so I'm going to try and get to the gearbox earth tonight and give that a good clean up, and the same with the battery terminals.
    Thanks for the help
    Posted 19th Sep 2012 at 09:45
    No problem, glad you got to the bottom of it. Thumbs up
    Posted 19th Sep 2012 at 16:54
