RJ
| Author | Subject: tps |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
Hi all where can i get a gti-6 new TPS to buy ________________________________________ RJ |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Moved to correct section, please try and put things in the appropriate section.________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
stan_306gti6
I believe the sensor itself is made by Bosch, so you could try and source it through the manufacturer direct.Failing that find a Peugeot dealer in the UK that would be willing to post, I know there are a few that do. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
ebay ? |
stan_306gti6
If you're lucky enough you *might* find one on eBay. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mpieczko
Regular Location: Birmingham Registered: 11 Mar 2009 Posts: 236 Status: Offline |
I spent about £15 on a pattern part on ebay and it has been absolutely fine.If you want a Bosch sensor then I have a second hand one for sale on here at the moment. |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
TPS from a XU10J4R (306 Xsi) is the same and much cheaper.. |
speedo306
where can you send me a link ![]() ________________________________________ RJ |
bas_306gti
speedo306
thanks mate ________________________________________ RJ |
