£25 posted
| Author | Subject: BakerBM lower bush & mount |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Bought this 2nd hand to go on my 309, hence it's already pressed into a housing. Had been fitted to a car for a while and so is a little grubby, but has only covered a mile or so of actual use. £25 posted ![]() ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Moonstone6
Regular Location: Lichfield Registered: 11 Apr 2012 Posts: 268 Status: Offline |
Hi mate I take it this is for the 306 gti? I would you take £20 posted? And is that damage to the aluminium housing? |
Moonstone6
Moonstone6
nock nock ??? |
24seven
Moonstone6 wrote: nock nock ??? I've not been online all that much today. £25 is the lowest I'll take as it's not the lightest thing in the world to post and the bush itself is easily worth that alone. Yes the ally housing/mount is from a '6 engine. Where are you looking at for the damage? There's a few scuff on it naturally for it's age, and without digging it back out of the packaging, looking at those photos all I can see is a few marks which look like someone's missed the drive shaft with a hammer while removing it (I bought it as you see it, I didn't remove it)________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
24seven
Bump________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Moonstone6
24seven
24seven wrote: £25 is the lowest I'll take as it's not the lightest thing in the world to post and the bush itself is easily worth that alone. Yes the ally housing/mount is from a '6 engine. Where are you looking at for the damage? There's a few scuff on it naturally for it's age, and without digging it back out of the packaging, looking at those photos all I can see is a few marks which look like someone's missed the drive shaft with a hammer while removing it (I bought it as you see it, I didn't remove it) ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
24seven
Sold!________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
