Author Subject: faulty fans
aaron6
Hi all, my fans have packed up. The a.c. don't work and neither do the fans. Any ideas?
Relay? If so.. which one is it?
Posted 8th Sep 2012 at 19:56
Is it the complete operation of the fans?
With the ignition switched on to the second click, unplug the brown sensor and see what happens. You should get both fans spin half speed for about a second or two and then go full speed.
If only one fires up at full speed you have a fan issue. If nothing happens, you've either got a knackered Bitron unit, and knackered brown sensor or one of the relays melted. The relays are located at the top of the fans, in their own little black triangular box. Yes
Posted 8th Sep 2012 at 21:02
aaron6
My bad, interior heater fan. Smile
Posted 8th Sep 2012 at 21:28
Check the green relays in the passenger fuse compartment, these are known to cause problems Aaron. Yes
Posted 8th Sep 2012 at 21:46
aaron6
Cool. How do you tell if they are ok or not? Fuse maybe?
Posted 8th Sep 2012 at 21:48
Have a look at the relays, make sure you can remove them and that they are not melted into the socket.
Do you have a Haynes manual Aaron? It has the diagrams in there and tells you what all the fuses are associateed with. I have one, but it's in the garage and I'm not in there now. If not, I will have a look for you when I next go in there. Smile
Posted 9th Sep 2012 at 08:19
aaron6
Sorted. Was the relay. Location wise the green relays are in 2 rows. The one which controls the heater unit is on the top row nearest the drivers door. As for how to check it...
Posted 9th Sep 2012 at 19:31
jord294
Well done Stan +1
Thumbs up
Posted 9th Sep 2012 at 20:12
swiftyboi006
Problem sorted so easily, dont normaly happen on here
Black p3 Love
Posted 9th Sep 2012 at 20:28
aaron6
Whoop whoop! I knew it could only be a handful of things but the forum is great for finding other faults or location and procedures. £5 well spent. Smile
Posted 9th Sep 2012 at 20:38
swiftyboi006
Definatly has helped me alot putting that blaze right again Thumbs up
Black p3 Love
Posted 9th Sep 2012 at 21:01
aaron6
I do like that blaze. Smile
Posted 9th Sep 2012 at 21:17
Glad it's sorted Aaron, had a feeling it might have been a melted relay. Thumbs up
Posted 9th Sep 2012 at 22:01
aaron6
Good call. Smile
Posted 9th Sep 2012 at 22:18
aaron6 wrote:
Good call. Smile
I'm just glad it was an easy fix, nothing worse than an electrical fault you can't diagnose...
Posted 9th Sep 2012 at 22:24
rich306
Never seen a buggered relay before, quite impressive!!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 9th Sep 2012 at 22:31
aaron6
Now you know what to look out for. Wink
Posted 10th Sep 2012 at 10:03
