RJ
| Author | Subject: Cam Sensor |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
What problems do you encounter when the cam sensor is not functioning properly or faulty.________________________________________ RJ |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Moved to a more appropriate section.________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
stan_306gti6
It will take ages to start as the engine uses the cam sensor as a reference for engine position during the starting phase only. Once it's running, it is not used. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
fatlapit
thought it was used for the sequential ignition or something!!________________________________________ |
stan_306gti6
fatlapit wrote: thought it was used for the sequential ignition or something!! ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
fatlapit
Oh ok________________________________________ |
stan_306gti6
It's a strange one really, because the lower spec head (which uses the one long coil pack) has the casting for the cam sensor but doesn't have the hole cut out for it...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
fatlapit
Juch rich w said it uses it as a trigger for the sequential bit.________________________________________ |
stan_306gti6
fatlapit wrote: Juch rich w said it uses it as a trigger for the sequential bit. Interesting...Rich knows his stuff, will have to ask him about this. ![]() It has been under intense discussion before and the end result was that it was used only for starting, will double check. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
