cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: Snapped Wheel Bolt |
swiftyboi006
Jacked up the front of the car went to take the wheels off and snapped a wheel bolt in the hub....ffs is heat and extractor the best way?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stan_306gti6
If there is a bit of bolt sticking out of the hub, you could try tapping it round with a hammer and small chisel...otherwise it's the extractor method. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
darzmat
Senior User Location: nairn Registered: 14 Jan 2011 Posts: 879 Status: Offline |
drill a hole in the middle of the bolt. smack in a torx bit, and undo with a ratchet________________________________________ 1997 blaze GTI-6 bought january '11 £800 Spend to date on parts £827.88 |
swiftyboi006
Gna heat it up and use the extractor 2mo. Still got 4 bolts that the air gun would not budge 2 on each side. Gna use the breaker bar 2mo as i didt think i would need it with an air gun ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
the reason it snapped is that is it seized or over tightened and as a result i very much doubt you will get it out, had this a few times. If you do try then get lots of heat on it with gas |
stan_306gti6
They can also get seized because people don't grease the bolts. I always grease wheel bolts, it stops this exact issue from arising. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Also could try welding a nut on and undoing it that way |
swiftyboi006
Such a p**sflap, since my dads my boss and does f all all day he said he will give it a go with some heat this morning________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Lowercase
Regular Location: Uckfield Registered: 24 Apr 2012 Posts: 227 Status: Offline |
happened to me too mate. i had to take the caliper and disc off to expose a bit of the bolt. welded a big m12 nut onto it and got it out while it was all still hot. ________________________________________ 1992 205 Rallye - S2 Rallye Engine |
swiftyboi006
My fecking dad just drilled the hole out and fecked the thread.......![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
New Hub time!Tbh they are only like 40 on here anywho ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
http://www.carparts4less.co.uk/cp4l/c/Peugeot_306_2.0_1999/p/car-parts/car-transmission/transmission-parts/wheel-bearing-and-wheel-hub/?629540020&1&a958aafa0721bb08d4488f88170d4904c8eb72f3&000602 http://www.carparts4less.co.uk/cp4l/c/Peugeot_306_2.0_1999/p/car-parts/car-transmission/transmission-parts/wheel-bearing-and-wheel-hub/?628545030&1&487c57ea2450c3dea58726e277846f73c6c0fa2b&000370 job done. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
GTI-6
Regular Location: Brisbane Registered: 18 Apr 2012 Posts: 163 Status: Offline |
Retap what metal?If he's drilled the thread out, you are basically ****ed. Unless it's straight, in which case, you could drill it out and heli-coil it. However, its a wheel bolt - you kinda want them to stay in place ![]() Copperslip in future! It's the dog's ![]() ________________________________________ Love thy 6 |
russbez
second hand hub?________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
ballardpaul
Seasoned Pro Location: Croydon Registered: 22 Jul 2008 Posts: 4,135 Status: Offline |
If you buy second hand make sure you change the bearings as I bought a second hand hub which was meant to have bearings that were fine to reuse, and Rich said they would of been dangerous to drive about on. Good thing I fitted them and the car never made it back onto the road till after the bearing was changed. ________________________________________ Phase 2 Blaze GTi 6 (Standard) SoldPhase 3 Supercharged China GTi 6 (249.8 BHP) Sold Phase 3 Supercharged Diablo GTi 6 (443 BHP)Sold Nissan 350Z (300 BHP) |
