Author Subject: coolant pressure cap
deano9621
fitted my nissens radThumbs up but just want to know if i can still use my pug cap on the new radDunno or should i use the one that came with the nissens radSmile
french forever
T859HFC now goneSad
T534 KVR now new homeSmile
Posted 29th Aug 2012 at 22:05
fatlapit
use the one that came with the rad, probably be the same tbh
Posted 29th Aug 2012 at 22:19
jeffers Forum Admin
My nissens rad came with a metal cap, I don't like them personally so I used a genuine one and have had no problems! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 29th Aug 2012 at 22:47
deano9621
Cheers LeeThumbs up don't go much on the metal cap either..prefer to use genuine capBig grin
french forever
T859HFC now goneSad
Posted 29th Aug 2012 at 23:00
I used my genuine cap on my Nissens rad too. Yes
Been fine for the last 4 years...Thumbs up
Posted 30th Aug 2012 at 09:55
deano9621
cheers guysThumbs up just want it original as possibleWhistle
french forever
T859HFC now goneSad
Posted 30th Aug 2012 at 10:16
buy a new cap from peugeot.
Posted 30th Aug 2012 at 11:12
Why if there's nothing wrong with the existing one? Unsure
Posted 30th Aug 2012 at 11:17
deano9621
used the one of my old rad....just as good,and works fineSmile
french forever
T859HFC now goneSad
Posted 30th Aug 2012 at 22:36
Do you notice the engine stays slightly cooler with the Nissens rad now? Mine always did. Smile
Posted 31st Aug 2012 at 06:36
deano9621
defo a lot coolerYes ..but since i put my old pug rad cap on i think its loosing a small amount of coolant,soYes i put oYes n the one supplied with the nissens rad....and so far so good,if this cures the problem i will oThumbs up rder a genuine pug one....as it was off the old rad,which has had to deal with a lot more pressure as the old one was knackerd and been on the 6 since new...
french forever
T859HFC now goneSad
Posted 1st Sep 2012 at 20:16
Good stuff, Nissens rads are definitely the way forward in my opinion. Yes
A genuine rad cap I think is about £8 from Pug so you'll soon be sorted. Thumbs up
Posted 1st Sep 2012 at 22:19
Sure it's coming out the cap ?
Posted 1st Sep 2012 at 22:44
deano9621
defo not anywhere else....looks like cap as there are signs of coolant around cap and run marks leading down from there....new cap from nissens on at the moment just to make sure,then if alls well will change for new pug one and go from thereSmile
french forever
T859HFC now goneSad
Posted 2nd Sep 2012 at 00:23
jeffers Forum Admin
Mine did exactly this, new cap sorted it!
Posted 2nd Sep 2012 at 01:43
Perhaps I was just lucky then using my original genuine rad cap then? Dunno
I'm sure I'll have to replace it at some point as it won't last forever.
Posted 2nd Sep 2012 at 08:09
Is it leaking any excess from the overflow/pressure valve on top of the rad/next ti cap?
Both caps fit, the nissens one doesn't stay nice n shiny like when new, it soon goes dull and looks s**te!
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 2nd Sep 2012 at 08:21
jeffers Forum Admin
The overflow/ pressure relief is controlled by the cap! Hence the leak being repaired by fitting a new cap! Roll eyes
Posted 2nd Sep 2012 at 10:31
Indeed, it's the spring arrangement on the underside of the cap which manages it. Yes
Posted 2nd Sep 2012 at 16:13
deano9621
i found out what was happening to the coolant in my new radThumbs up ..i was putting in a bit too much,near close to top of radNo ....when it was happy at about 5m below seal on the neck,so i ran the rad with the nissens cap for a few days to be sure,and then put the o.e cap back on and all's fineBig grin
french forever
T859HFC now goneSad
Posted 9th Sep 2012 at 20:03
thought so, thats what i ment in my post, that if its overfilled then wether its the new cap or old cap whichever, it will still lose any excess till the level is right.
Posted 9th Sep 2012 at 20:25
deano9621
cheers for all the help guys....as always apreciatedSmile
french forever
T859HFC now goneSad
Posted 9th Sep 2012 at 20:29
