displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: Figuring Bucket seats
vlj
Has anybody got pictures of their subframes fitted into the car? Me and Matt are fitting these in the week but the seats are so low on the floor it doesn't seem right
Team Black 6
Posted 30th Aug 2012 at 18:14
If they're made for the 306 they should just bolt into the four original mounting holes I'd have thought.
Posted 30th Aug 2012 at 18:15
vlj
Yep.
Sliders aren't here yet but I can't see how they will give any more height
Team Black 6
Posted 30th Aug 2012 at 18:29
Eurgh, no idea what's going on there. Worryingly it looks like it's close enough to be the right kit but badly made, rather than just the wrong kit.
Why did you not just get the DT kit which bolts straight in as one unit and has the sliders? I can't even see what that kit's trying to do.
Posted 30th Aug 2012 at 18:31
vlj
I hope you speak Italian
Team Black 6
Posted 30th Aug 2012 at 18:44
Matt_rallye
Dude how low are these? Sliders should be with you today or tomorrow according the the invoice, be interesting too see how much lower than standard these are
Posted 31st Aug 2012 at 08:51
old photo, but you have them upside down. the metal bar would hit the underside of the seat otherwise
i used fixed sparco ones with these but in the end i f**ked them off and got proper ones
Posted 31st Aug 2012 at 08:58
vlj
Aaaah makes so much more sense now.
I only received the flat base and the adjuster to fix to the side though, where did you get the other side rail type bit from?
Team Black 6
Posted 31st Aug 2012 at 09:10
the sidemounts came with the sparco seats i bought (i got them new, 2x sparco evo's)
the only thing i did was space the sidemount up about 5mm off the subframe for some reason, i think it was to make a final seat adjustment
Posted 31st Aug 2012 at 09:20
vlj
Post #35
Hmm strange I only received 1 side mount, although saying that surely I only need 1 for the side wall on the outer side? Or are they needed both sides for the seat to bolt to
Team Black 6
Posted 31st Aug 2012 at 09:22
Post #36
ohh sorry you mean the actual bit that bolts to the shell, not the bit the seats bolt to visible in my photo? (the upright bits)
you only get 1 sidemount per side. you need them exactly as my photo
yo have the angled brackets which bolt to the outer sill, and link to the main subframe (you have these on both sides) then you can mount sidemounts depending on your seat like my photo
you could always do this:
http://i835.photobucket.com/albums/zz272/richard306/seatbars_installed_4.jpg
Hyper
Posted 31st Aug 2012 at 09:25
vlj
Post #37
Just realised what's going on the sides are for a fixed base we have sliders so all is well. Ill let you know in a couple of hours
Team Black 6
Posted 31st Aug 2012 at 09:27
Post #38
i imagine if you put adjustables ontop of the ones you showed, your seat is going to end up quite high. i once had some Cobra Daytona buckets with adjustable subframes and they sat quite low. i'm 6'3 and they didn't feel overly low so i imagine if you are putting 2 together they may make them quite high. worth a try though
Posted 31st Aug 2012 at 09:31
vlj
Post #39
The sliders are just cheap ebay jobs and don't look like they will add too much height, I'm not exactly the tallest person going anyway and Matt isn't much taller than me.
Hopefully the sliders will be here today so I can fit it all and let you know
Team Black 6
Posted 31st Aug 2012 at 09:34
Matt_rallye
Post #40
That base (albeit up the right way) the sliders bolted to it, the bolt the buckets to slider should be good to go. The buckets are side or bottom mountable so think we are going for bottom mounts with the sliders.
Just need bottom mounts for passengers an then we are well away.
Also Vaughan did DT get back to you about only sending you one drivers side mount? We need two drivers mounts lol
At worst passengers can have a standard seat till we sort it out haha
Posted 31st Aug 2012 at 10:25
ed_doe
Post #41
When you lot have figured out how to mount these in, can you talk me through waht kit you actually need; I think I'm gonna have to get a set of those sparco seats for sale on oc from that Trackbasedtuning bloke.
Vaughan I assume that's where you got these from mate?
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 1st Sep 2012 at 16:27
vlj
Post #42
Hey mate,
With the Sparco kit it does mount in but personally I am absolutely on the floor, and to be honest it's not a fantastic piece of kit. We've ordered up the OMP frames instead as from research I believe them to be of better quality and fitment, and will be using those with sliders. I'm hoping that the OMP frames will sit a little higher, if not I'll have to look into either buying spacers or side mounts.
All in all, go OMP.
Team Black 6
Posted 1st Sep 2012 at 16:42
7057sam
Post #43
I had omp basemounts,ended up selling them then got cobra mounts the sliders actually made them to high.now running them fixed(mounted directly from seat to base mount) still could do them going lower mind.I found the whole fitting bucket seats and getting a perfect driveing position very hard, hope you have more luck.
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 1st Sep 2012 at 16:58
vlj
Post #44
What made you change from the OMP bases?
Team Black 6
Posted 1st Sep 2012 at 17:05
7057sam
Post #45
Well i could of used them then bolted my seats too them(would of probs been better that want it did).
I was on limited time to get ready for pugfest so just bought direct fits from tweaks.
P.s do you now they in stock as shortly after i sold mine i heard they were out of stock in the uk.
Rallye dead Sad
Posted 2nd Sep 2012 at 21:14
vlj
Post #46
we have ordered them and it doesn't say they are out of stock so hoping for the best.
Team Black 6
Posted 2nd Sep 2012 at 21:18
Lowercase
Post #47
what frames are these in the pics? and are they dear?
1992 205 Rallye - S2 Rallye Engine
Posted 3rd Sep 2012 at 18:57
vlj
Post #48
They are the Sparco frames. 60 quid each or 45 posted in my for sale thread.
Team Black 6
Posted 3rd Sep 2012 at 19:24
Lowercase
Post #49
you happy with the ease of fitment? ergonomicaly and what not.
Posted 3rd Sep 2012 at 19:45
vlj
Post #50
Fitting them is easy but I'd recommend using sliders and side mounts unless you are above 6ft2ish
Team Black 6
Posted 3rd Sep 2012 at 20:07
Pages (3): 1 [2] 3
