displaying posts 1 to 25 of 28
Author Subject: Demon Tweeks
daytime6
Has anyone brought Omex Ecu and wiring loom from these as not sure if will get all the right connectors ect
Anyone help?
Posted 23rd Aug 2012 at 23:08
pugpower1986
hey pal my partners brother works there m8 ... what info do you need ill get it Smile
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 23rd Aug 2012 at 23:10
daytime6
I'm thinking of buying just the Omex 600 ecu and wiring loom does it come with the base map you need to get it going and does the loom you get come complete with all you need to plug and play?
Posted 23rd Aug 2012 at 23:14
fatlapit
get in touch with miles (pugracing) mate. hes only in fordingbridge
Posted 23rd Aug 2012 at 23:36
daytime6
You reckon he's got one that I need?
Posted 23rd Aug 2012 at 23:39
Got my Omex from Jenvey, it can come as a basic wiring kit with pretty much the plug and some wires and you sort it all out yourself, great on a race car where you are probably replacing all of the wiring, but not so great for everyone else. The other option is a pre made universal loom, this is a professionally assembled plug and play harness with a main connector for the ecu, then everything from coolant/air temp sensors, ignition coil, injectors, throttle pot, rev counter, shift light and fuel pump. You will need to order the appropriate sensors if you don't have them. Are you going for bodies?
Posted 23rd Aug 2012 at 23:41
miles
The universal loom is just that, Will be a mess when installed and if using on a 6 engine you'll need either a external coil pack or the XSi coil pack, That's unless your using the 710 ECU
Best bet is the un-terminated loom as you can run a Lambda, Fan relay etc
Fitting is quite easy on the 6, So a custom loom won't cost the earth, I have a few maps as well and mapping 5 mins from me
www.pugracing.com
Posted 23rd Aug 2012 at 23:53
pete_rallye
They will provide a base map if you give them the engine and cam details, and can usually e-mail it to you...
As Jim says, the loom can come complete which is ideal if you are a novice, but does mean you may have excess wiring in places, or unterminated, so labelled cables fitted to the ecu plug, but no plugs for injectors, coil etc. You then have to cut those to length, crimp the terminals on and fit the terminals into the plastic housings. It's really pretty easy and will give a tidier finish. You can usually program the ECU to read the sensors you have, and not all of them are compulsory.
Lap of the 'ring
Posted 23rd Aug 2012 at 23:56
daytime6
Yer going down the throttle bodies route .i brought them off a mate of mine ,I was going to buy the kit d.tweeks sell ,that's the option I was going to go for the universal pre made loom but was just wondering would that be all I need as new I'd need the sensors I.e t.p.s and a.t.s and coolent sensor
daytime6
Yet I'm a deffinatly novice to all this ,how much you reckon it will be to get someone to wire it up for me or is it more expensive then buying the pre made loom?
Posted 23rd Aug 2012 at 23:59
pete_rallye
The TPS is known as a colvern type,nd should come with the kit. Chances are you'll need a seperate single coil, rather than 4 individual ones, I think I used one from a 405, but theres loads about, although there are 2 different plug types, a 4 pin and a 3 pin I think. Coolant sensor you have is fine, you just tell the ECU to read that sensor, air temp should also come with the kit and again, you can tell the ECU what to read, probably best to mount it on the throttle body air filter backplate.
I reckon i would take me a few hours to sort the loom out, and whilst I know what I'm doing, it's not like I do it everyday so an auto electrician should be less, so maybe £50-£60 for a couple of hours work?
Lap of the 'ring
Posted 24th Aug 2012 at 00:00
miles
Only need a P&G TPS (Colvern type of worst) & ATS, all the other's can be Pug, The lambda is best being swapped for a 3 wire one.
Also what inlet you running as I will have one of mine with a Custom inlet RR Next week all being well (Daveyboy) knows about them too, as the Jenvey one is too short really.
www.pugracing.com
Posted 24th Aug 2012 at 00:02
miles
Coil wise it's best like this
The XSI pack fit's with the old coil pack tab's removed, Saves having horrid HT Leads
You can also see the inlet length here too
Not many maps at Omex, I've only ever been supplied one, But I know they can mod them slightly if you email them, Trial and Error but with a standish engine the base map runs OK but must be RR before driven on the road
www.pugracing.com
Posted 24th Aug 2012 at 00:04
pete_rallye
Also, I know it comes as a kit from DT, but I'd speak to DTA also, they do a similar kit and I found the DTA ecu's much easier to work with than the Omex, but I guess it comes down to what experience your engine mapper has.
Lap of the 'ring
Posted 24th Aug 2012 at 00:05
daytime6
I got the inlet with the TB's which also the 90mm trumpets for £150 bargain.I was thinking of using a coil pack like ya said miles off a xsi.is wiring up the loom diffeant from phase 1-3 or they pretty much the same as mines a 3
Posted 24th Aug 2012 at 00:12
daytime6
The nearest mapper around my area is matt at m-tech and I've seen his work and looks pretty good but that's just the first I've seen
Sorry for dragging it out but these kinda things need to be done proply then cutting corners
Posted 24th Aug 2012 at 00:15
miles
What Omex ECU is it?
Loom wise it's all the same no mater what ECU, remove complete engine loom and re-wire from there, You can bodge the old engine ECU loom in but it's not the best practice, The only thing you use from the old engine loom are the sensors for water and oil temps and switched live for the various relays and ECU
Loom wise depends on the spec of the car, I've got my relays in the old relay box but all of the old ones are long gone,
Joy's of aftermarket wiring, there's no such thing as plug and play, well for a neat install anyway
www.pugracing.com
Posted 24th Aug 2012 at 00:21
fatlapit
If that is that clown from westbury do not go there he is s**te. use ktec or mekmotorsport
Posted 24th Aug 2012 at 00:22
daytime6
Was going to use the Omex 600 as was going use use a coil pack like ya said.were abouts are the other places based fatlapit?.jow much do you charge to wire up the loom to the engine?
Posted 24th Aug 2012 at 00:34
miles
Ktec are 5 mins from me in Verwood, Andy is bang on knowing the box's inside and out, And after years of various mappers I can say he's by far the best
www.pugracing.com
Posted 24th Aug 2012 at 02:40
daytime6
If I'm right is that down by we're they do the sunseeker rally in the forest stage ?,
Posted 24th Aug 2012 at 09:23
birk
Ive got to make a loom for my dta, im not looking forward to it because i think it will be quite hard.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 24th Aug 2012 at 09:26
daytime6
That's my worry also if I do it myself , which i don't realy want to waste money on the look and bugger it up 😒
Posted 24th Aug 2012 at 09:56
I use a DTA and there is'nt actually a huge amount to it when you look at it.
  • Posted 24th Aug 2012 at 10:08
    Matt_rallye
    Miles what are ktec like for setting up bodies etc? Or is it just mapping they will do?
    I'm looking into bodies and cams soon, the only thing really stopping me was the fact I toughy I'd have to drive miles to get any help with mapping/setting up.
    Posted 24th Aug 2012 at 10:59
