Author Subject: Fuel gauge not working
demondriverdan
Put some fuel (~20L) into the track car earlier to find that the gauge didn't move, just thought it was very low on fuel when I bought it rather than there being a problem.
Is it just a sensor I need to change?
Rallye Race Car
Posted 22nd Aug 2012 at 23:28
pete_rallye
Check the sender, its built into the fuel pump housing on Ph2 and 3's, and separate on Ph1's. You should check the resistance changes as you move the sender, or just make sure its not stuck. You could just move it by hand and see if the gauge moves too. If not, could be wiring or a dodgy dash.
Lap of the 'ring
Posted 22nd Aug 2012 at 23:46
demondriverdan
Taken the sender out and put a voltmeter across it; getting 10v (ish) to the sender. When running a bit of wire from the positive pin to any other pins, the gauge doesn't move on the dash.
Any thoughts?
Rallye Race Car
Posted 27th Aug 2012 at 16:08
Sounds like it could be a problem in the instrument panel then. However, 10v to me is a little low to start with. Wink
Have you checked the resistance on the sender as you move the float arm?
Posted 27th Aug 2012 at 17:11
demondriverdan
Didn't have chance to pull the sender out today, but get to that during the week.
Rallye Race Car
Posted 27th Aug 2012 at 21:15
Ok, keep us posted on the result mate. Smile
Posted 30th Aug 2012 at 15:31
demondriverdan
Slight update, replaced the pump unit with a second hand unit from Dan and still no gauge. Also noticed that the dash lights aren't working either.
Am guessing there's a dodgy connection to the clocks so will be checking that out at the weekend.
Rallye Race Car
Posted 27th Dec 2012 at 19:03
Hope that just highlights dan as a bad seller.
Posted 27th Dec 2012 at 22:10
Yep, deffo sounds like an instrument cluster problem. Yes
Posted 28th Dec 2012 at 16:11
demondriverdan
Are there any issues with swapping instrument clusters from 1 car to the other? Thinking of quickly putting the cluster from the road car into the track car to see if that solves the problem.
Rallye Race Car
Posted 30th Dec 2012 at 11:30
Nope, just swap them over. Yes
Posted 30th Dec 2012 at 13:52
demondriverdan
This problem is still a, errrr, problem? Did a bit more investigation over the weekend and the sender on the pump is working fine so there's another problem elsewhere. I've fixed the dash lights issue (no connection going between the pins on the dash dim plug) so I'm thinking there could be a bigger problem.
When the ECU resets the fuel gauge needle moves and the light goes out (along with all the other needles) before returning to it's zero position. Could it be that the ECU believes there's no fuel in the tank and thus is sending that to the gauge?
Rallye Race Car
Posted 24th Mar 2013 at 17:56
ecu has no connection with fuel gauge.
Posted 24th Mar 2013 at 18:33
demondriverdan
Well there goes that plan! Is it the dash itself resetting then rather than the ECU (causing the dials to move)?
Other options must be either a dodgy dash or broken wiring somewhere.
Rallye Race Car
Posted 24th Mar 2013 at 19:26
demondriverdan
Still a bit stumped as to what's causing this. Sender is outputting a value that changes based on position so that seems to be working fine.
Does anyone have a diagram of the clock connectors so I can check what value is being sent to the clocks? See if it's the clocks broken or a bad connection somewhere.
Rallye Race Car
Posted 16th Jul 2013 at 15:02
tvrfan007
I appreciate the age of the thread so this is a long shot. Do your time clock, rev counter and mileage display work?
If not, check fuse 25 I think it is. This has killed my fuel gauge off twice already in my Rallye.
Regardless, wiring diagram are in the FAQ. I was looking at these previously.
http://www.306gti6.com/forum/showthread.php?id=134863
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 29th Jul 2013 at 12:16
demondriverdan
Fixed it in the end, turned out to be the clock unit was broken. Got a replacement set of clocks and the gauge works fine!
Rallye Race Car
Posted 29th Jul 2013 at 12:46
scotzman
Good to hear they are all working Thumbs up
Posted 29th Jul 2013 at 13:30
This is a very good call, saves you bags of time checking fuses first. Smile
Posted 29th Jul 2013 at 19:17
demondriverdan
On the old clocks everything was working except the fuel gauge and possibly odometer back light
Rallye Race Car
Posted 29th Jul 2013 at 19:25
