Author Subject: Some Greasy Bits
Eddleston
OK, I've had a little look under the bonnet for the first ever time and found it's all pretty grubby.
However, some bits are wet and grubby too. Not what I was wanting.
First one I noticed was the pipe going to the throttle bit is a bit oily. Any ideas?
Secondly, I noticed some wetness at the back of the block, passenger side, under this round thing. Slap bang in the centre of this picture. O-ring leaking? Dunno
and finally, what is this connection for? (behind the strut, top left of engine bay)
It's ok, I'll run out of questions soon Razz
Posted 16th Aug 2012 at 15:17
russbez
the oil coming from that pipe is normal, shouldnt really be getting out though
the point where it meets, there might be a rip
not sure now... its been a while since iv seen standard setup LOL
looks like your vacuum pump is leaking.... possible seal might need replaced?
(iirc they arent much!! b**ch to pull the vacuum pump off, had the pleasure of taking one off my old engine to refit to another)
thats the wiper motor plug
My Rallye project thread
Posted 16th Aug 2012 at 15:23
Second pic, that's the vacuum pump. The seal is probably leaking.
  • Posted 16th Aug 2012 at 15:25
    Eddleston
    Best get me a Haynes manual soon then. Time to lose more skin.Roll eyes
    Posted 16th Aug 2012 at 15:44
    This is your online Haynes manual.
  • Posted 16th Aug 2012 at 15:51
    russbez wrote:
    looks like your brake servo is leaking.... possible seal might need replaced?
    So as not to confuse the bloke, the brake servo is the large round black item on the bulkhead where the master cylinder comes out from.
    It's the Vacuum pump which he has pictured which is leaking.
  • Posted 16th Aug 2012 at 15:53
    russbez
    hah sorry, vacuum pump ill edit that
    Posted 16th Aug 2012 at 15:57
    matt evans
    There are two seals on the vacuum pump for the servo, big ones about 60p, the little buggers a couple of quid, easy peasy to change though
    honestly3k wrote:
    owain wrote:
    Posted 16th Aug 2012 at 16:22
    Eddleston
    +1 lad point
    Posted 16th Aug 2012 at 16:25
    Just for reference, the Haynes Manual's don't actually cover the GTi-6/Rallye. No
    The manual for the 306 does however cover the XSi 16v which is a very similar setup and you can use the directions for that for most jobs on the 6/Rallye. Thumbs up
    Posted 16th Aug 2012 at 16:27
