Author Subject: Hello, New Here
Eddleston
Hi all,
Just acquired my dad's red 306 Rallye. Just a little different to my old Hilux Surf!
Just a couple of questions along with being a newbie,
1) It seems to get pretty warm in traffic or just going slow in town. Like 95ish - I put the heater on full whack after that, didn't fancy testing the temp limits after one day. What should it be at as a 'normal' temp? (My old Rover's head gasket was dead so I had to put up with endless over heating. Also after changing the Hilux's water pump it never overheated afterwards. Do I need to think about these previous experiences?)
2) I've been told the cam belt failed a few years ago, I guess that's where the ticking noise came from. Judging by the stuff written on this forum, I guess it's the timing not 100% perfect. only seems to be audible above 2000rpm.
3) Dad seemed to think the clutch is knackered, any recommendations? main dealers and the like can sod off.
4) Central locking works from passenger side, not drivers side, is this a known issue? Maybe a connection somewhere?
5) looking around at some front splitters and most seem horrendous, anything nice and subtle anyone can recommend?
6) Will be getting an alarm/immobiliser system installed once I get a little more money, I'm sure some of you have ones you can recommend.
Should be a good few months ahead of fun Smile
Alex
Posted 15th Aug 2012 at 18:10
arigti6
Howdy. Wave
I am not a mechanic by any means but I believe the '6/rallye do have a tendancy to run hot in traffic but out of experience (HG failure on mine 2 yrs ago) I would suggest getting it checked over.
Again with regards with the tapping if it was a 'snaper' that would be best being checked for peace of mind.
Someone on here will be along who is able to give you more benoficial advise LOL
Welcome to the club! Smile
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 15th Aug 2012 at 18:35
Welcome mate Wave
Posted 15th Aug 2012 at 18:37
heliosphan
Rad cooling fan should kick in at around 97 degrees IIRC, so sounds like it's normal. Mine does it and I think all other Gti's/Rallye's do too. Still scary when you're not used to it though!
Welcome by the way.
Posted 15th Aug 2012 at 18:44
mik
Another Red Rallye is always welcome!
For parts I would check main dealers first to get a feel for the price. I say this as I found a pattern exhaust from a well-known chain was the same price as a genuine one from the dealers. So I would always check first you may be surprised on some things but not on others.
Cherry Rallye SOLD
Posted 15th Aug 2012 at 19:52
Eddleston wrote:
Hi all,
Alex
Wave welcome! as said another Rallye is always welcome Smile
check out the standard ph2 splitter that's just a black strip that runs along the bottom of the bumper
water sounds about right these do get quite hot in traffic as long as your fans are running ok you shouldn't have a problem
if clutch needs changing its quite a big job either engine out or box off while in the car,.. a few people on here may be able to help you out as there are a few mechanics on here! swerve the main dealer's don't call them Peugeot monkeys for nothing!
central locking try looking at the door loom where it meets the body of the car see if there's a bad connection or broken wire maybe,
it should already have a standard alarm immobiliser,.. what you'd probably spend more on some top notch thing than you'd safe on you're insurance anyway! just don't park anywhere shady and it should be fine!
garage would be a bonus!
Posted 15th Aug 2012 at 20:05
Miami205gti
Welcome m8.
Pug 205 gti 1.9 Miami blue
Pug 207 gt hdi
Posted 15th Aug 2012 at 20:58
pug pete
welcome bud
Posted 15th Aug 2012 at 21:00
JayKay
Welcome Wave
Mine has a tendancy to run hot in traffic and i'm not a lover of hot running, when i bought it the fan switch wasn't working so i wired a switch to the dash(sorry die hards, it's discreet!) Just lets me control it properly!
You'll find all the info you need in here somewhere, just use the search bar! Thumbs up
'Keep The 6 Between The Sticks'
Blaze Of Glory, 6 FTW
Posted 15th Aug 2012 at 21:11
mik
Rallyes have key code immobiliser only, there is no alarm like there is on GTI-6.
Cherry Rallye SOLD
Posted 15th Aug 2012 at 21:52
mattgti6phase2
Welcome. Wave
Head gaskets aren't really a problem on these engines it's all to do with how it's been maintained, like caning it from cold etc. mine has covered 120k and is on the original head gasket. One common cause for HG problems is the cooling fans not working and the car over heating massively.
In general these engines are pretty damn strong so as long as you maintain it you'll be fine Yes
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 15th Aug 2012 at 22:28
Welcome to the club! Wave
Posted 16th Aug 2012 at 07:01
peetypug
Welcome matey
Can't beat the old cherry rallyes!
They do run hot, specially when the fan doesn't kick in! May be worth making sure it does kick in though
The last thing you want is a cracked block like mine did from a none functioning fan!
Go for the standard gti6/rallye splitter
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 16th Aug 2012 at 07:45
russbez
welcome Yes
My Rallye project thread
Posted 16th Aug 2012 at 15:17
mellowr1
allo. Welcome Smile my 6 gets up to 97 in traffic but once the fans kick in it soon comes back downThumbs up
Posted 16th Aug 2012 at 15:59
braymond
Hello matey,
To add further reassurance on the fan/temperature issue, that sounds normal. For info, a search on here may reveal two temperatures at which fans kick in, but the Rallye only has 1, to the GTi-6's 2.
Enjoy it! Thumbs up
Rallye-R
Nurburgring article
Posted 16th Aug 2012 at 16:28
milkyb
what radiator you got, mine was terrible, always over heating in traffic, since getting a nisens rad, its seldom over 90. happy motoring
Posted 16th Aug 2012 at 16:29
Eddleston
Enjoy it! Thumbs up
Wondered where the other one was, worth another one?
Still got the original, bit manky. Was thinking a nice shiny new one wouldn't go a miss.
Posted 16th Aug 2012 at 16:43
milkyb
DEFINITELY get an upgrade
Posted 16th Aug 2012 at 16:49
deano9621
Hello and welcome,all a good bunch on hereBig grin
french forever
T859HFC now goneSad
T534 KVR now new homeSmile
Posted 16th Aug 2012 at 17:38
Matt_rallye
Welcome along mate Smile
Posted 17th Aug 2012 at 17:32
mcvite
Welcome mateThumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 18th Aug 2012 at 01:21
craig-gti6
welcome along bud, i've got a nissens rad and since its been fitted i've had no problems with overheating. Would defo reccomend.
Posted 18th Aug 2012 at 13:48
