In my ownership it hasn't turned under it's own power and has been kept clean and dry indoors in one of the uni workshops where I have made sure to oil and crank it manually occasionally while it's in one piece. It was stripped from the Xsara by a krisb on here.
I've also got a spanking new idle control valve a VSS sensor needed for the speedo drive in a 205/309 conversion and almost-new BBM lower and gearbox mounts that I'll throw in with it as it's all of no use to me now.
£300 the lot to your door or £220 collected from Swansea
Conveniently it's still on the pallet from when I took delivery if you want to arrange a courier.
24seven
