displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author Subject: one for the wiring gurus......
yeah take plenty of pics so you know where all the wiring is routed, also the labels are a good idea, although most don't fit in the wrong ones, it would still help and you will feel more confident about the job then.
I had my air temp sensor wiring plugged into the reverse sensor an vice versa for around 6 months LOL
Car ran good still aswell.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 14th Aug 2012 at 13:29
BlackSix
Big grin and they say the french dont do wiring, eh?
im used to doing mechanical bits and bobs, but never really tried to tackle wiring Smile
Posted 14th Aug 2012 at 13:31
most of the plugs are keyed so will only go on certain sensors, plus are colour coded
what is the problem again? your car doesn't run? or does, but badly?
Posted 14th Aug 2012 at 13:43
BlackSix
does but badly and most of the sensors have been replaced.
the loom is a total screw up, whoever did it hasnt got 2 brain cells to rub together by the looks of it
Posted 14th Aug 2012 at 14:48
replace loom, you can get them for about £20-25. but if the loom has been butchered or bodged there may be a reason
Posted 14th Aug 2012 at 14:50
If the loom is as bad as you say it is, then a replacement will be necessary. Yes
It's an hours job for someone who hasn't done one before I would have thought, they're not hard to change. Smile
Posted 14th Aug 2012 at 15:00
This is one of those jobs you could actually outsource to your wife while she's waiting for your tea to cook.
Purely an uplug and remove, and then lay it into position and plug it back in.
Not only are the plugs colour coded and aligned to go on the correct sensor, but the shape of the loom puts the plugs near to where they want to go. You'll have a clump near the throttle body for example, so once you have plugged one or two of them in, move down the loom and when you find a plug, find a sensor that it matches. If you are stretching it over the engine, it's obviously wrong.
  • Posted 14th Aug 2012 at 15:25
    BlackSix
    well its in and was quite easy. hardest bit was those 2 plugs down by the rad.....spent half the time swearing before i just smashed the collars off them.
    plugged it all back in, second turn of the key she started Big grin
    id tripped the fuel cut off switch Razz
    still not very smooth at idle though. how do yours run?
    Posted 14th Aug 2012 at 20:12
    Icv ? New ? Cleaned ?
    Posted 14th Aug 2012 at 20:17
    BlackSix
    Post #35
    new. ive been told that they all do it, mines noticeable sat in traffic
    Posted 14th Aug 2012 at 20:19
    Post #36
    Has the running of the car got any better now since you fitted it yesterday? Unsure
    These cars are not the smoothest of idlers out there, so what you're experiencing now is probably normal. Yes
    Posted 15th Aug 2012 at 09:34
    BlackSix
    Post #37
    yeah it has got better, just feels like the occasional stutter instead of several times a second.
    Posted 15th Aug 2012 at 11:34
    Post #38
    There's obviously a further fault still present, possibly now simply a sensor fault as the wiring has been replaced. Try cleaning the exhaust tip and then going for a drive and see what it looks like when you get back. If it has got excessively sooty then something is obviously causing it to run rich etc.
    Posted 16th Aug 2012 at 08:09
    Pages (2): 1 [2]
