am currently running the standard air box with a pipercross filter. but am after some induction roar now.
any advice or comments welcome
| Author | Subject: induction kits |
mike rallye
Seasoned Pro Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
hi guys am looking at getting some sort of induction kit and am not sure weather to go for the k&n or the pipercross viper induction ?am currently running the standard air box with a pipercross filter. but am after some induction roar now. any advice or comments welcome |
JWP EFi
mike rallye wrote: hi guys am looking at getting some sort of induction kit and am not sure weather to go for the k&n or the pipercross viper induction ? am currently running the standard air box with a pipercross filter. but am after some induction roar now. any advice or comments welcome the K&N's give the loudest roar in my experience, cone obviously |
Standard airbox and performance filter inside will give the best results/powerinduction kits in my experience although sound good,lose driveability on these engines for sure ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
induction kits normally suck hot air into engine too unless properly ducted (i.e. not a 50p piece of wrinkly hose cable tied to the filter). ________________________________________ Cherry Rallye SOLD |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
I have a (smashed) BMC CDA box, hate it. Can't wait to get the standard box back on..(Shame crspares sold me a scrap worthy box and stole my money) ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
BlackSix
Regular Location: northampton Registered: 30 Jul 2012 Posts: 156 Status: Offline |
all ive done is took the snorkel out of the air box. makes a bit more induction noise but still got the original piping.best bit is...its free |
daver6
BlackSix wrote: all ive done is took the snorkel out of the air box. makes a bit more induction noise but still got the original piping. best bit is...its free Which snorkel? The one that sits over the rad? ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
BlackSix
no the one inside the airbox. if you take the air filter out and stick your arm up there youl feel it.simply pop the pipe to the throttle body off and push that pipe up it pops out |
mike rallye
ok cheers guys think i will stick with standard airbox ,should i get k&n panel filter then? and i will look for that snorkel |
mik
Snorkel sits in the top of the airbox. It is a plastic tube. ________________________________________ Cherry Rallye SOLD |
mike rallye
well i decided to try an induction kit for a bit,as i understand what you guys have said.but thought i have one for a bit,but i need to get a breather for it.but my question is could i drive with out a breather over the weekend? or if someone local to me has for for sale that be gd? |
mike rallye wrote: well i decided to try an induction kit for a bit,as i understand what you guys have said.but thought i have one for a bit,but i need to get a breather for it. but my question is could i drive with out a breather over the weekend? or if someone local to me has for for sale that be gd? Its not a breather its your idle control valve intakeTweeks should have a filter,18mm IIRC ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mike rallye
ok yeah that what i meant, should it be ok to drive then till monday till i can get there. ? |
swiftyboi006
If you want to suck up debris then yes, if your that desperate go to halfords________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
mike rallye wrote: ok yeah that what i meant, should it be ok to drive then till monday till i can get there. ? Yeah be fine swiftyboi006 wrote: If you want to suck up debris then yes, if your that desperate go to halfords Only sucking in air at idle,so can't see it being a problem for a day or two Unless Mike is planning on doing some Paris to Dakar rallying through the desert! ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
JayKay
Junior User Location: Poulton-le-fylde Registered: 11 Aug 2012 Posts: 87 Status: Offline |
Pipercross induction kit on mine, Definately gives it more power over the standard filter system and it sounds absolutley ficking amazing!________________________________________ 'Keep The 6 Between The Sticks'Blaze Of Glory, 6 FTW |
swiftyboi006
"________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
JayKay wrote: Pipercross induction kit on mine, Definately gives it more power over the standard filter system and it sounds absolutley ficking amazing! A loada hot air mate, see what I did there |
mike rallye
well i got to wait till tweeks tomorrow to buy a reducer before i fit it now. but will have it chucking loads of cold air to it those as am still using one part of the air filter. |
mike rallye
does anybody no the outer diamter size of the throttle body? am not sure if it is 70mm? |
mike rallye wrote: well i decided to try an induction kit for a bit,as i understand what you guys have said.but thought i have one for a bit,but i need to get a breather for it. but my question is could i drive with out a breather over the weekend? or if someone local to me has for for sale that be gd? Get one of the ones on eBay for £4.45 delivered I Think it is. Auto Silicone Hoses. ________________________________________ ![]() |
mike rallye
well i have fitted my induction kit ,which sounds brilliant when driving, but am woundering what you guys think is the best way to mount it.would you say the way i have done it is the best way as i dont want it down on the floor.?![]() ![]() ![]() ![]() as you can see from pictures i have use part of the old cold air feed to allow more more direct cold air feed,i just need to sort some pipe out for the breather or get hold of another breather pipe if anybody got one for sale? comments and advice will be take on board if i could route it better |
