displaying posts 1 to 25 of 33
Author Subject: TAP TAP TAP
JWP EFi
Turbo Legend!
afternoon chaps, this morning when i went to start my 6 it has just developed a tap, yesterday i topped the oil up with
10/40 synthetic
i have checked the plugs - they are tight. only had this car for few days and hasnt done this till today
i'm going to put a flush through it then change oil and filter on monday
i'm a big baffeled as to why its just started doing it, i have masses of paper work/history and there is nothing to
say the heads been off or broken cam belt etc etc so
Posted 11th Aug 2012 at 15:02
aaron6
It won't be valves if it just started doing it. Check for damaged plugs. Also, sometimes the injectors can get a bit loud, could it be that? Mines get tappy from the liters when it's done 6k miles. Might just need a service. 10/40 is fine though. Smile
Posted 11th Aug 2012 at 15:21
JWP EFi
Turbo Legend!
it is almost like the injectors are the cause, i will stick a forte fuel treatment through it see if that helps
car is due to be serviced, last done in Feb and has done approx 5k since so this will be done on monday
plus the cam belt and pump, the box n clutch.........where does it all end lol
Posted 11th Aug 2012 at 15:25
JWP EFi
Turbo Legend!
Btw car has only done 165k!!
Posted 11th Aug 2012 at 15:26
aaron6
Be sure to use a genuine oil filter as they have a non return valve that most of the pattern ones don't. Wink I would also use a genuine Campbell kit as I've had failures with pattern ones.
Posted 11th Aug 2012 at 15:35
It'll be Stan he's a slippery bugger, he hides in bottles of oil.
Posted 11th Aug 2012 at 15:41
daver6
I've never been given a filter without this and I get whatever ECP classes as their best quality filter. Mann, Bosch and a few more
Wishbone Polybushes available
Posted 11th Aug 2012 at 15:58
aaron6
All the ones I ever got have not had them but a pug one ain't expensive anyways.
Posted 11th Aug 2012 at 17:13
Laugh my ass off
Posted 11th Aug 2012 at 17:17
It's probably just a lazy lifter, will most likely clear once you've carried out a fluid change. Yes
And as stated, get a Peugeot (Purflux) filter when you do the service. Thumbs up
Posted 11th Aug 2012 at 17:18
JWP EFi
Turbo Legend!
the more i listen to it the more i think it is a lifter, i put the stethoscope on to cam cover and seems
to be coming from valve gear rather than injectors. Weird how its just started tapping though,
but saying that up until i got the car it was used on a daily basis, since then i have only been moving it
in and out the garage before and after work, so am condifident a good servive will cure it
Posted 11th Aug 2012 at 21:26
Yeah I heard it was lube oil aswell, the stuff they sell at pulse and
Cocktails Yes
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Aug 2012 at 21:29
I forgot to ask Stan - How does your hot tub perform now that you changed over to a Purflux?
  • Posted 11th Aug 2012 at 22:06
    LOL
    Not sure mate, I haven't used it since I serviced it. LOL
    Posted 12th Aug 2012 at 07:24
    JWP EFi
    Turbo Legend!
    finally i have a 6 that fixes itself overnight...erm anyway, as said earlier since i got her ive barely
    driven it, now lastnight when i was trying to pin point the noise it was running for a hour or
    so, today i started it up and the tapping has gone, so oil and filter change tomorrow, hopfully
    it never comes back
    Posted 12th Aug 2012 at 20:03
    Matt_rallye
    Mine did this, rebuilt the head, sounded good, did a little drive, then left over night and now it taps, think its the lifters though as while the head was off the lifters were dry stored :/ no idea how to easily fix
    Posted 14th Aug 2012 at 22:51
    My old engine did this sometimes, seemed to be worse when she was hot/ at running temp.
    It wasn't a tapper as in bent valves though.
    Posted 14th Aug 2012 at 22:58
    Change the lifters for a full good working set. I'm not sure if they can be cleaned and checked but you would have to do all of them Yes
    Posted 14th Aug 2012 at 22:59
    aaron6
    Jsa, sounds like mine. Sometimes it taps a bit sometimes it smooth as silk. Mines deffo a lifter so it really don't bother me. Just lets me know when to do the oil. LOL
    Posted 14th Aug 2012 at 23:01
    Matt_rallye
    Argh, that means cams out again :/ cba, may just put up with the tap haha
    Posted 14th Aug 2012 at 23:20
    JWP EFi
    Turbo Legend!
    LOL
    i got her Mot'd n taxed yesterday, took it for a good run and its not tapped since, btw, engine is very strong to say
    she's coming up to 166k Smile
    As long as i get my clutch/box and timing belt done this week i'll be doing my first trackday at Knockhill this
    coming sunday, this will let me know if theres any life left in it lol
    Posted 14th Aug 2012 at 23:30
    aaron6
    I'm sure it's fine. Let us know how the car performs. Thumbs up
    Posted 15th Aug 2012 at 05:43
    You can get lifter treatment which you put in with the oil. It's supposed to clean them out and unblock all the oil ways to allow them to work properly once again.
    However, having never had to use it myself I wouldn't know how well it works, but it might be worth a try for you boys suffering with lifter issues on and off?
    Posted 15th Aug 2012 at 09:23
    aaron6
    Wynns do one but I'm reluctant to use it incase it loosens something up that's better off left alone.
    Posted 15th Aug 2012 at 10:10
    I know what you mean mate, sometimes these can do more harm than good but this is generally associated with oil flushes etc. Yes
    I've never had a problem with my lifters, but I reckon they might be quite tappy if I ever start the engine again as it's been sat without running for nearly a year already. LOL
    Posted 15th Aug 2012 at 11:20
