Author Subject: 205 BE1 gear lever
jonnie205
Half way through fitting a gti6 box in a 205. i cant find a be1 gear stick, i need this so i can use the lift up reverse. Is the be1 pull up collar on gear stick the only part i need or does anyone kow if the be1 gear lever is different in some way to the be3 one
cheers
Posted 10th Aug 2012 at 15:28
The BE1 lever has a white bit on it which the BE3 one doesnt have. It's attached through a tiny hole in the BE1 lever.
Do you need the plastic sleeve collar shaft lift up thing? I have one if so.
  • Posted 10th Aug 2012 at 16:08
    jonnie205
    yeah like a 306 gti i assume? there is s clip on the gear lever to hold the outer cable and the inner cable is clipped into the pull up collar?
    Posted 10th Aug 2012 at 16:10
    Yeah.
    I don't think you can buy this white bit seperately.
    Can't help you with the stick as someone bought it for similar reasons as you, but I have the sleeve here.
  • Posted 10th Aug 2012 at 16:40
    I think Dan ( DCC ) has the white clip unused, you can fit this to a BE3 stick as all it needs is a hole for the roll pin, which afaik should be there as the stick itself is the same part number for BE1 and BE3.
    Posted 10th Aug 2012 at 17:07
    I have 2 BE3 levers here and neither have the hole, so it's odd there's no varying part number.
  • Posted 10th Aug 2012 at 17:17
    jonnie205
    thanks for the help will be in touch
    Posted 10th Aug 2012 at 17:31
