displaying posts 201 to 225 of 230
Pages (10): first .. 8 [9] 10
Author Subject: Nialls GTi6
Niall
Post #201
calibra306 wrote:
Niall wrote:
No mine are the correct offset and direct fit. The 16s just have really deep bolt holes unlike the 17s
mine are 17in
Yeah and the bolt holes on yours are no where near as deep as the ones on the 16s. Don't know why they are different but they are. It's a pain in the arse really as my socket literally only just reaches without smashing f**k out of the bolt holes.
Posted 6th May 2014 at 14:25
pugheaven
Post #202
Is the chirp noise not the recirc valve, mine makes that noise when im at high boost/rpm and then let off
Posted 6th May 2014 at 14:29
Niall
Post #203
What recirc valve you using?
Posted 6th May 2014 at 14:31
pugheaven
Post #204
Bailey
Posted 6th May 2014 at 14:33
pugheaven
Post #205
Go on you tube and search recirculating dump valve, the top video was an evo, listen to that, its what mine sounds like
Posted 6th May 2014 at 14:47
t3ora
Post #206
Any updates
Road/track car coming together slowly
Posted 25th May 2014 at 21:48
Niall
Post #207
t3ora wrote:
Any updates
Well sort of! Nothing to write home about but i have redone the whole engine bay loom as it was bodged together to get it in for mapping in time. Also relocated the ECU to in the cabin now to make it easier to have the laptop plugged in and so no one will run off with it when the bonnet is up at shows LOL
The back has always been too low in comparison to the front 30mm drop so this afternoon i raised that up to a more sensible height
Also went for a drive down to the New forest the other week and a friend got some good photos
Also now that its fuelling correctly and boosting correctly (and next weekend will be boosting even more as I'm fitting my -17% pulley), its not mapped correctly which i did not want to drive it on to the shows so its back in for mapping on June 5th Smile
Posted 25th May 2014 at 21:58
jammapic
Post #208
Stunning mate. Looks really well put together!
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 26th May 2014 at 16:17
Niall
Post #209
Its not LOL
Posted 26th May 2014 at 22:17
rallyestyle
Post #210
Niall wrote:
Its not LOL
For doing it yourself its bloody good Thumbs up
Just Drive It
Posted 27th May 2014 at 21:38
Niall
Post #211
Cheers man. Mapping is just over a week away now. Getting nervous again now LOL
Posted 27th May 2014 at 22:24
eddy_gti6
Post #212
Hope you have more luck than me! Mine should have been done last monday. Its a week and 2 days later now and still no further forward LOL
Posted 28th May 2014 at 00:22
Post #213
Be interesting to see what you get out of it with the smaller pulley on. What sort of boost level will it be running? I've often wondered if you'd get more low down grunt with a smaller pulley on a rotrex. You'd have to lower the rev limit though so to not over spin it.
Posted 31st May 2014 at 18:18
Niall
Post #214
Well a friend kindly fitted the pulley for me yesterday (took a hydraulic press in the end to get it on LOL ) and I've fitted it back onto the car and taken it for a quick spin. Not booting it as its over fuelling on boost quite badly but it does boost a lot earlier which is nice. Hoping to see 7-8psi. Problem with this charger though is i can't go any smaller than this pulley now as the pulley actually sits over the snout annoyingly unlike most where its on the end of the snout so you can go as small as you like.
Car is now all ready for mapping and cleaned for FCS so just needs a quick wipe over Friday. Charger isn't in the best of shape. Its making the boost it should do fine but sounds like the end bearings are on their way out as you get an occasional knock from the rotors. Just hope it lasts until after mapping and FCS LOL
Posted 1st Jun 2014 at 18:14
Niall
Post #215
That's a bit better Smile
Posted 6th Jun 2014 at 09:44
walker_texasranger
Post #216
Awesome!!! You happy with that?
Hilux InvincibleX daily
306 No.13 Doh
Posted 6th Jun 2014 at 15:14
Niall
Post #217
Yes mate. anything above 200 was a bonus for me so I'm happy with it
Posted 6th Jun 2014 at 15:31
Castor_Troy
Post #218
Loving the laguna splitter Love
Posted 6th Jun 2014 at 15:42
Post #219
214 not bad for a home brew to be honest pretty well 50bhp on top.
I'm really struggling with mine at the minute. I'm trying to fit a gigantic intercooler as well as oil cooler and traction fluid cooler behind it.... Proving to be a nightmare.
Posted 11th Jun 2014 at 23:22
rallyestyle
Post #220
That's a great result Thumbs up
Do you think there is more potential in there somewhere to get a bit more power?
Would be great if you could squeeze 250 out of the setup Yes
Just Drive It
Posted 12th Jun 2014 at 09:35
rallyeash
Post #221
Torque looks a little low?
309 3dr K20 Type R
Posted 12th Jun 2014 at 10:59
ryangti6
Post #222
I'd be interested to see this against a low boost rotrex. The torque looks quite good to me especially low down.
Good effort especially for doing it yourself and doing something a bit different to everyone else Thumbs up
Ryan
Posted 13th Jun 2014 at 11:57
Post #223
180lb/ft isnt bad for 215bhp. mine made (on a 30 degree day) approx 250bhp and only just over 190 of torque.
Suprchargers dont make torque like a turbo does as its not free driven power.
Will be interesting to see what mine makes now ive tweaked it a bit and got a cooler 3 times the size lol
Posted 13th Jun 2014 at 13:16
Niall
Post #224
Thanks mate. Im pleased with it for a lashed together setup lol. There are other guys out there with 250 on a similar set up but that really is pushing it and I'm not after chasing figures. Im after having something thats fun which this now ticks all the boxes for!
Always more potential my friend! Again, i was really struggling with heat on the dyno. At one point he actually had the hose from the air conditioner over my air filter and i was still seeing 35 degrees but that was when he was really putting it under some load...to the point where my back bumper started melting as my exhaust is too close lol. Next move is an enclosed air filter and potentially a more efficient IC. Also to move the oil cooler from in front of the IC to on top so its not blowing hot air through.
I didn't think 180 was bad for 215hp considering a lynx kit is about about 205-210 for 250hp. Don't forget, eaton chargers are a completely different beast to a rotrex which is proved with graphs. These run out of puff at higher RPMs which you can see on the graph yet the Rotrex chargers seem to give a very smooth line of torque. No one can argue that on paper, the Rotrex is the better charger but at quite a considerable extra cost and is that extra cost worth the extra 30-35hp? Imo, not really. Oh and you don't get that noise Thumbs up
Posted 13th Jun 2014 at 18:12
Niall
Post #225
Oh and 2 videos because we all like videos Smile
http://youtu.be/y6mvG6gZCOo
Final power run
http://youtu.be/AtG9W7FaaD0
Quick demo of my new PLX gauge. Great bit of kit and great value. Just need to get the oil pressure and boost pressure inputs for it now.
Posted 13th Jun 2014 at 18:17
