Author Subject: Jobs to do while engine out?
vik
Is there anything that I should do if I'm taking the engine out anyway, to make life easier in future?
So far on my list.
New timing belt/water pump
Heat wrap exhaust manifold
New driveshafts
Anything else? Is it worth/necessary to change any of the mounts/etc?
Posted 5th Aug 2012 at 18:22
Personally I'd check over absolutely ever last bush and fixing you can find and if even looks slightly worn, replace it.
Steering rack and ram are also far easier to get to, how about a cheeky Xsara VTS steering rack upgrade while you're there?
Posted 5th Aug 2012 at 18:37
check the bulkhead for rust, and chassis legs, also brake lines.
Posted 5th Aug 2012 at 18:42
mik
Rust anywhere in engine bay would be my no 1 priority.
Cherry Rallye SOLD
Posted 5th Aug 2012 at 19:11
Clutch and clutch fork bushes.new clutch cable also
Posted 5th Aug 2012 at 19:24
Check it's got a supercharger
Posted 5th Aug 2012 at 19:53
pugpower1986
i got a xsara vts steering rack for sale Smile
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 5th Aug 2012 at 20:10
matt evans
So far on my list.
New driveshafts
Id refresh the engine mounts, checking the top mount cup for cracking as well. Plus renew the front and rear main oil seals and rear hockey stick seals if your pulling the engine apart. Then look for and treat the rust that will be present in the engine bay somewhere, sooo much easier with the power unit out of the way.
honestly3k wrote:
owain wrote:
Posted 6th Aug 2012 at 09:40
Probably good time to change the rack.
But I would say rust is number 1
Posted 6th Aug 2012 at 09:52
you could literally do anything with the engine out. i have mine out at the moment and i'm doing belt, pump, lower pulley, all new gaskets, took the inlet off and chucked a PTFE one on, then powdercoated the inlet, new driveshaft seals, flywheel end and crank end crank seals, new VSS, new mounts, new radiator.. how far do you go?
Posted 6th Aug 2012 at 10:05
