Followed the faqs from here
| Author | Subject: Had a go at a cam belt change |
Well thought it was about time I tackled a cam belt change ? Never done one In the car and found it a little fiddly but not to bad all seems ok now it's back together and running Followed the faqs from here |
stan_306gti6
Nice one Bowen, well done. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Only snag I forgot to drain coolant - made a small mess when took water pump out |
720puggti
Seasoned Pro Location: West London Registered: 18 Jan 2009 Posts: 1,069 Status: Offline |
I can't believe you've never done a belt before Chris, I thought you were up on all mechanical work...________________________________________ Deepak Gohil |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
Congrats!![]() ________________________________________ Proud Member of the ASTOR Owners Club |
Awaiting "what went wrong?" thread.... Lol done loads of these engines now they look a lot worse than they are just need a known good bottom pulley! ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
stan_306gti6
bigbadbowen wrote: Only snag I forgot to drain coolant - made a small mess when took water pump out ![]() You'll know for next time though. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
BlackSix
Regular Location: northampton Registered: 30 Jul 2012 Posts: 156 Status: Offline |
what method did you use fr the aux belt? looks like a right bugger tbh |
stan_306gti6
BlackSix wrote: what method did you use fr the aux belt? looks like a right bugger tbh To change it or loosen it off to do the cambelt? You only need to loosen the 2 x 13mm bolts holding the tensioner on and then unwind the 6mm allen head tensioning bolt and the belt will go loose. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
BlackSix
cheers. doing mine at some point when i can be bothered lol. |
stan_306gti6 wrote: BlackSix wrote: what method did you use fr the aux belt? looks like a right bugger tbh To change it or loosen it off to do the cambelt? You only need to loosen the 2 x 13mm bolts holding the tensioner on and then unwind the 6mm allen head tensioning bolt and the belt will go loose. ![]() That's assuming you have the rallye aux set up ? |
BlackSix
Oh, no just. The standard 6 setup |
BlackSix wrote: Oh, no just. The standard 6 setup Then you will need to release the tensioner by using a ratchet and turning the whole thing to get enough slack on the belt |
BlackSix
dont know what i was worried about. off and on in 15 mins ![]() thanks |
You did a belt change in 15 mins ? Did you do water pump roller and tensioner ? |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
bigbadbowen wrote: You did a belt change in 15 mins ? Did you do water pump roller and tensioner ? ...he did his auxiliary belt. ________________________________________ Less than 24 hours to go! |
BlackSix
just the aux belt mate. |
BlackSix wrote: just the aux belt mate. Ah I see that's pretty easy then once you release the tensioner. Try swapping the set up over to a rallye version and see how long it takes |
BlackSix
i might do that actually, the piping and air con rad have already been removed by previous owner so it would make sense to get rid of the pump too. first got to sort the problems out though.cambelt and water pump were done shortly after i got the car, aux belt was meant to be done at the same time but was supplied with the wrong part. went and got a refund on it and ordered the replacement but dealing with the fault i kinda forgot til they rang today and said the belt has been sat on the shelf ages do i still want it haha |
Good luck then you will need it |
stan_306gti6
bigbadbowen wrote: Good luck then you will need it It's not that hard a task to change the setup over, just very fiddly and working in confined spaces. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
