| Author | Subject: Changing axle bushes heeellllppppp |
Moonstone6
Regular Location: Lichfield Registered: 11 Apr 2012 Posts: 268 Status: Offline |
Hi I have got one end of the axle down to replace bushes after hours or un seizing and I'm noticing the bolts which retain the mounts the one is fouled by the trailing arm please don't tell me I have to remove the torsion bars to move the trailing arm to remove the bolt to replace mounts your reply would be appreciated Taa lads |
yup if it has been lowered.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
As Mei said ^^^^________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Moonstone6
Job done I just managed by releasing the damper and using a bar to lever it so much difference using some fresh pug mounts the old ones were bo**oxed been a busy day |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
I was going to say you can do it by removing the lower damper bolt and forcing the arm down, we had to do that on Rich's lowered rallye when his rear mounts were fooked. Bit of a ball ache, the nearside, in comparison the off side was a 10 minute job...________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
Did this on my xsara VTS beam and the n/s bolt was fouled by the trailing arm just cut the old bolt out with a grinder and put a spare through the other way job done took 5 mins .________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Moonstone6
armzs16 wrote: o this is good news I was thinking only one side of my axle had been lowered Did this on my xsara VTS beam and the n/s bolt was fouled by the trailing arm just cut the old bolt out with a grinder and put a spare through the other way job done took 5 mins . mine was the same just undone the damper and the bolt wasn't Fouled by trailing arm |
Nah it's only the near side because of the position of everything. The VTS axle was at standard height which is about 25mm lower than a 6 one.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
