I have found these ?C5 Stelleies? but there is no product code to be found!! Is it the right ones ??
I dont want to start finding a set of MICHELIN PILOT EXALTO PE2 if it is not the right rims!!
jakob5_10 has attached the following image:
| Author | Subject: The "right" C5 steelies ?? |
jakob5_10
Newbie Location: Copenhagen Registered: 20 Mar 2012 Posts: 10 Status: Offline |
HiI have found these ?C5 Stelleies? but there is no product code to be found!! Is it the right ones ?? I dont want to start finding a set of MICHELIN PILOT EXALTO PE2 if it is not the right rims!! jakob5_10 has attached the following image: |
16 holes which from comments and pics I've seen seems to be a common visual identification from a distance. Someone will clarify.________________________________________ ![]() |
got a magnet?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jakob5_10
they are definitely alloy (no rust and other stuff)So my question should be: Are there any heavy alloy "steelies" with 16 holes ?? |
no.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jakob5_10
to put it in Danish !!Jubii!! and for the low price of 0 dkr :-) |
peetypug
Seasoned Pro Location: Spooning marksorrento205 Registered: 20 Feb 2011 Posts: 1,869 Status: Offline |
![]() That's the best picture I can find ________________________________________ Cherry rallye - DOB Thursday 29/04/1999Team Rallye - the leaner, meaner, better looking sister of the GTI6 ![]() roland rat wrote: You sir either live for the 6 or have a mental retardation to still be repairing this! The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental. |
jakob5_10
thanks a lot for all the help !! I have after a good cleaning, located the number and indeed it appears to be the correct ones :-)Now i just have to decide if i should get hold in 5-6 more witch I can get for around 120€ for winter tire and spares!! What do you carry as a spare ?? |
I use a C5 wheel as a spare ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
