Author Subject: Adjusting gear rods
Had to tweak mine due to fitting a Compbrake quickshift,so the info might come in handy for someone in the futureThumbs up
Can only be done with aftermarket/Miles gear rods thoughSmile
If you are struggling to get 2nd/4th/6th/reverse you need to shorten the large gear rod,if your struggling to get 1st/3rd/5th the large gear rod needs to be lengthenedThumbs up
Posted 2nd Aug 2012 at 16:30
honestly3k
Handy info this Thumbs up
Hopefully i shan't need to touch the lengths of mine from the off
Posted 2nd Aug 2012 at 16:55
JayKay
coskev wrote:
If you are struggling to get 2nd/4th/6th/reverse you need to shorten the large gear rodThumbs up
Just the post i've been looking for Thumbs up
'Keep The 6 Between The Sticks'
Blaze Of Glory, 6 FTW
Posted 13th Aug 2012 at 07:34
When you remove your existing ones, lay them next to the new ones and ajust to match.
  • Posted 13th Aug 2012 at 07:53
    Glad to help Thumbs up
    Posted 13th Aug 2012 at 09:11
    hismastersfinger11
    out of interest... can anything be gained from adjusting the other two shorter linkages?
    Without any knowledge.. (i just stuck mine on at standard length) i would guess one would allow you to adjust the throw of the stick, and the other the resting position of the stick.
    Anybody tried messing about with them at all?
    This site is my mechanical bible, Thank-you everyone!!
    Posted 13th Aug 2012 at 09:49
    No they wont affect the throw whatsoever, you need to alter the leverage ratios to do that
    Posted 13th Aug 2012 at 10:21
    hismastersfinger11
    So maybe they both just alter the resting position of the stick then, seeing as I like where it already is there is not much point fiddling... just wondered really
    Posted 13th Aug 2012 at 10:41
    beez_neez_gt
    Nice one Kev il lengthen mine n see if it sorts it. I did match mine with the old one, it doesnt always work due to many other tolerances down to having taking car parts all off etc.
    This thread should be a FAQ.
    +1
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 15th Jun 2013 at 21:54
    beez_neez_gt
    I did mine one turn n it is better, lower gears are just as was, think I still need another turn as its getting stiff after a much longer drive.
    Pug fee`ver,
    Posted 16th Jun 2013 at 20:48
    24seven
    Try adjusting the gear rods that attach to the selector arms on the gearbox as well as the one underneath. If these are too long or too short you can find the L bracket rotates around it's axis such that its leverage is reduced which would make the gearstick feel heavier and notchy. I don't have adjustable rods on my '6, but on my 309 and 205 I set up the "feel" of the gear shift using the smaller 2 and adjusted the position of the stick a little forwards as to my liking using the long rod underneath the car.
    Posted 17th Jun 2013 at 18:29
    Top info ...got mine coming Thumbs up
    Posted 2nd May 2014 at 18:47
