displaying posts 1 to 25 of 34
Author Subject: hesistaion
mike rallye
evening guys and girls.
over the last few weeks i got slight hesitation maybe misfire when drive from cold and doing about 30mph in 4th gear and am woundering if any one has any ideas,could it be temp cooloant sensor or coil packs. i have replaced the lamdor sensor about 13months ago and replaced to coil packs 8 months ago.
any ideas would be helpful.
Posted 30th Jul 2012 at 21:36
ryangti6
I would of said Lambda but seeing as you've replaced it maybe not. Was it a good make like Bosch you fitted or a cheapy one? I've known people to have s**tty motorfactor one's fail in no time at all but if it was a good one I'd say it's safe to rule that out.
If it goes when the car is warm then it does point to the green, ecu temp sender. They are cheap enough so a new one is probably worth a try.
Ryan
Posted 30th Jul 2012 at 21:42
mike rallye
yeah it was a bosch one, think it cost about £40 ish. i might just try temp sensor. would it matter if i didnt get none geniune one?
Posted 30th Jul 2012 at 21:51
I'm in agreement with Ryan, it sounds like the engine is being starved of the fuel it needs when running cold.
New CTS time, may as well get one from Pug, I think they are around £13 so not dear. Smile
Posted 31st Jul 2012 at 10:54
mike rallye
well i ordered the CTS and ecu sensor, and i still have a the same problem. but if i drive in 3rd gear doing 30mph all is ok ,it just when i change to 4th gear at 30mph it just doesnt like it.
it is little better when warmed up a little bit.
so any other ideas guys?
Posted 6th Aug 2012 at 19:25
Sounds abit like mine.
I'm going to try air temp sensor,couple of people on here said try itThumbs up
Posted 6th Aug 2012 at 19:52
BlackSix
did you reset the ecu after fitting the new parts?
also, try disconnecting the MAP sensor while its running. if it dies, its fine but if it carries on running it needs replacing
Posted 6th Aug 2012 at 21:30
mike rallye
no didnt reset the e.c.u but might do that now and leave it disconnected for a bit,and will try disconnecting the map sensor to.
Posted 6th Aug 2012 at 21:58
mike rallye
well i just disconnected the map sensor and tat cut out after couple of seconds ,so that working fine. i have also disconnected the E.C.U to and left it for 15 mins and just re connected and been down the road as seem ok,but will confirm tomorrow on way to work i should now then.
thanks for the advice guys
so tryed it today on way to work and still the same after resetting the ecu. ideas needed?
Posted 6th Aug 2012 at 22:24
mike rallye
bump any ideas anyone?
Posted 9th Aug 2012 at 18:29
^^This would probably be the next port of call. Yes
Posted 9th Aug 2012 at 18:32
mike rallye
were is that located?
Posted 9th Aug 2012 at 19:49
BlackSix
back of the throttle body the grey plug
Posted 9th Aug 2012 at 19:55
Cheers Stan,Mike seems to only read what he wants to readThumbs up
Posted 9th Aug 2012 at 23:40
mike rallye
i just mis read it that was all ,wasnt ignoring your comment honest Thumbs up , should hopefully have one of these next week, does anybody know the part number as my local peugeot dealer system is down at the moment.
Posted 10th Aug 2012 at 22:35
http://www.306gti6.com/forum/showthread.php?id=136521
Thumbs up
Posted 12th Aug 2012 at 01:36
mike rallye
cheers mate
Posted 12th Aug 2012 at 22:42
mike rallye wrote:
cheers mate
If you haven't ordered allready:
http://www.ebay.co.uk/itm/AIR-TEMP-SENSOR-PEUGEOT-DACIA-NISSAN-RENAULT-CITROEN-/261082047590?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc9b3e466
Posted 15th Aug 2012 at 22:49
mike rallye
thanks for that link mate, bought it straight away so will let you know if it works
Posted 16th Aug 2012 at 00:39
mike rallye
have received the air temp sensor today ,which game in a really stupid size box for a small item.well anyway once i removed the old one,i notice there was no o ring on it and the top of the tip was little black and worn. so will try it later on and hope it works.
Posted 18th Aug 2012 at 12:18
jord294
Have you sorted the back end of the car yet?
Posted 18th Aug 2012 at 12:35
mike rallye
no not yet hope to do it next weekend. only had it happen once since i came to you. just been out for a drive and it seems spot on at the moment.
Posted 18th Aug 2012 at 14:11
Seems like a success then so far...Smile
Hopefully the issue will now be cured. Thumbs up
Posted 19th Aug 2012 at 16:18
mike rallye
still having problems with this intermittently ,what do we suggest it could be ?
Posted 23rd Aug 2012 at 18:26
Wait until you are experiencing the problem reasonably bad and then pull over and whip the plugs out...
The colour of these will tell you a lot about what exactly what is happening inside the combustion chamber during the issue you describe and then you will be able to see whether it's running too rich or too lean at that point. Yes
Posted 23rd Aug 2012 at 19:56
