KEN
Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS
| Author | Subject: mis fire !! |
skybluken
Junior User Location: bristol Registered: 16 Jan 2012 Posts: 100 Status: Offline |
Hi guys, got amis fire problem at low revs, but as soon a u give it some it kicks through it and is fine just happen on tickover and lumpy when on low revs, not sure if could be plugs/coils or maybefuel pump. Just changed fuel filter last week after car would die andkick straight back in when puttin some fuel in and old filter was well manky. Any ideas would b good going to take plugs outand check them or just replace them. Thanks allKEN ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Could be one of many things:- Lambda, doesn't work on WOT so could be to blame - MAP sensor - Idle control valve (stepper motor) Read the FAQ on testing sensors and go round them with a multimeter and you should find the culprit. |
wilyoldave
Seasoned Pro Location: Yeovil Registered: 21 Apr 2007 Posts: 1,642 Status: Offline |
Had something similar - turned out to be the lambda.________________________________________ No more peugeots![]() Snap - no more RS clio ![]() Now Ph1 RS clio |
BlackSix
Regular Location: northampton Registered: 30 Jul 2012 Posts: 156 Status: Offline |
dud you get this sorted in the end? |
skybluken
Not sorted yet got a new lambda. Not had time to fit it. More than likely goin to b monday. Will post the outcome hopefully that will sort it after the hours i spent reading on here :-)________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
stan_306gti6
I would hazard a guess at the lambda being the cause. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
When you say misfire, do you mean it's popping or do you mean it's a cylinder that's not firing as some people call both of those symptoms the same thing?________________________________________ Less than 24 hours to go! |
skybluken
Just changed the lambda and reset ecu. Just done about 2 miles in it and seems ok will be goin out later doin about 20 miles so hopefully will be sorted. Old one was knackered all the end had split so i'm hoping were now sorted and my love affair with my 6 will be back on ;-)________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Thsi reminds me that I need tojust work my way around the car with new sensors as im SO not up for s**t like this happening randomly________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
stan_306gti6
skybluken wrote: Just changed the lambda and reset ecu. Just done about 2 miles in it and seems ok will be goin out later doin about 20 miles so hopefully will be sorted. Old one was knackered all the end had split so i'm hoping were now sorted and my love affair with my 6 will be back on ;-) Fingers crossed then. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
skybluken
Ok here goes car runs much better but still havin same probs. Fuel was low and then put a £10 of fuel in problem got better as fuel dropped problem came back noticed the fuel guage goin up and down so now thinking it could be a vacuum problem in fuel tank as i noticed a really long hiss when removing cap the other weekbut didint think much as weather hot. So removed cap and drove round for abit and its still there but not as bad. Fuel light stayed on as needle dropped and didnt go up and down as much which is making me think tank pressure! Cant find anything about air breather on tank. This has only got worse since i changed the fuel filter dont remember it being this bad before. Any ideas Please please :-( ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
stan_306gti6
You say you've changed the fuel filter, I take it you put the new one on in the correct direction of flow?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
skybluken
Positive but will double. But would of thought if that was the case it would happen all the time?________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
stan_306gti6
skybluken wrote: Positive but will double. But would of thought if that was the case it would happen all the time? I agree. To be honest, it doesn't sound like a fuelling issue if it only happens at low revs and you go through it and then it clears...I suspect a possible fouled plug which only cleans up under higher rpm or a coil pack that is on its way out. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
Clean the TPS |
skybluken
I'm thinking along the line of fuel tank breather/pump where its pulling fuel through andbuilding up a vacuum in the tank then it clearing causing it to die then breather opens giving the instant go?? Where is the breather cant find any thing on here normally its at the fuel filler neck i believe on other cars but cant see it??________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
skybluken
Changed tps & map sensors and was doin this before changed fuel filter but has got worse but seems to happen more when fuel low? Goin to fill the tank tomorrow when paid and see what happens ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
BlackSix
when you find out whats causing this, let us know mate. seems like im having the same symptoms.i "fixed" it earlier, albeit temporarily, it was idling and running brilliantly but this evening it went back to the fault ![]() ive got some wiring damage on a few of the wires going to the sensors on the throttle body by the looks of it. all i know is i repaired a few wires there and it seemed to work but now its back. il be checking my repairs tomorrow, but i cant be certain if id just moved another dodgy connection and its "slipped" again. mines defo a wiring loom problem though, 100% now |
skybluken
Hi all, changed the coolant temp sensor the green ecu one(£12 gsf) after doin all the above. car is running like a dream. Me now back in love again. just need to sort my fuel breather now so running around with a loose fuel cap but it works for now and have an accurate fuel gauge. Cant beleve how quick this car now is after doin all this and how well it runs. Thanks for all your help Ken ________________________________________ Diablo Phase 1 NOW DEADAlfa 156 2.0 JTS |
deano9621
Regular Location: plymouth Registered: 12 Sep 2010 Posts: 196 Status: Offline |
glad you got it sorted buddy....had a few problems with mine ,but all's fine and running perfect ________________________________________ french foreverT859HFC now gone ![]() T534 KVR now new home |
I think they all hiss don't they if it's been ran down from aFull tank? Not sure if mine does or not but I've seen this happen with loads of cars ad it never made them run bad ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
Glad this is sorted mate. Now we just need to get your car fixed BlackSix... ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
