Paul
displaying posts 26 to 38 of 38
Pages (2): 1 [2]
| Author | Subject: Peugeot 306 hdi rad fans |
Nitehawk10
Newbie Location: London Registered: 27 Jul 2012 Posts: 22 Status: Offline |
been told i dont have thermostat switch________________________________________ Paul |
There is a brown plug on the the thermostat housing that controls the fans on ac engines ? I assume you changed / removed this plug when trying to get the fans to work ? Non ac engines have a different set up. It's controlled by a thermostate switch located in the rad at the top right as you look at the car? Yours will have a blanking plug as you have aircon ? |
Nitehawk10 wrote: been told i dont have thermostat switch Correct you have a brown plug in the thermostate housing ? |
Nitehawk10 wrote: been told i dont have thermostat switch You need to look at a non air con 306 to see the difference |
Nitehawk10
ok cool i will check this out tomorrow and i will get back to you i dont recall in seeing one the only sensor i have changed is the blue one that screws in to the side of the engine called temperature sensor________________________________________ Paul |
Nitehawk10
if iam correct isnt this plug only on 1.8 and 19 diesel engine________________________________________ Paul |
Nitehawk10 wrote: ok cool i will check this out tomorrow and i will get back to you i dont recall in seeing one the only sensor i have changed is the blue one that screws in to the side of the engine called temperature sensor Brown sensor on the Gti 6 controls the fans ? Blue sensor is the sender to the dash ? |
Nitehawk10
but i have hdi________________________________________ Paul |
Nitehawk10 wrote: but i have hdi Same car different engine ? Pretty sure the loom and sensors are the same ? Will check my hdi in the morning but it has no aircon and I know it has a rad mounted thermostat switch |
Nitehawk10
Post #35
ok cool i start on mine in morning and get back to you________________________________________ Paul |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Post #36
bigbadbowen wrote: Yes we know that and as said you need to check that plug for corrosion ? It's nothing to do with rad it's attached to fan cowling ? You will need to remove the front of the car to get to the fan cowling and that plug It helps, but you don't have to you can get to it from underneath the car (on the hdi anyway, it's just fiddly). Aside from a bitron unit the fan principle is the same - HDi had the same twin fans as GTi6 with similar sensor setup as did most of the rest of them. I SAID BEHIND THE RAD ON THE COWLING IN THE FIRST POST FFS!! The first stage of fans is 12V through both so they run at half speed. The second stage is 12V parallel so they both run at full speed. If there is something wrong with the series circuit, you get no fans until stage 2 at which point I bet you've only got one fan running. Check the free stuff first before you start chucking money away on sensors. This is why i sent you the link to the fan plug. I've had two faults with my fans and one was similar to the one you described which was a missing 12V feed to the relays from the body loom. The plug being the second problem which allowed my fan to run all night by itself with the car switched off. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
Nitehawk10
Post #37
ive checked everything they all seem to be ok ive checked relays at front of car still having no luck________________________________________ Paul |
Nitehawk10
Post #38
all sorted i dont know what i done but there now working________________________________________ Paul |
Pages (2): 1 [2]
