displaying posts 1 to 25 of 38
Author Subject: Peugeot 306 hdi rad fans
Nitehawk10
Hi there iam having a problem with my rad fans there not cutting in when they should be I only noticed this other day when stack in traffic I ended up turning my engine off before doing any damage I have changed the thermo switch in the side of engine I have checked the fuses in the fuse box and in the engine bay they all seem to be fine when I unplug the switch both fan cut straight on in default mode
Any help would be great full
Paul
Posted 27th Jul 2012 at 07:07
Wait so when you pull out a temperature switch then they dont run on full but at normal pace?
Posted 27th Jul 2012 at 09:15
Nitehawk10
They both run full speed when I unplug it
Paul
Posted 27th Jul 2012 at 10:02
bellcp306td
What temp did it get to? they dont cut in full speed until 100c but should be on half speed at 95c
Where did the road go!
Posted 27th Jul 2012 at 10:58
Nitehawk10
All most 100
Paul
Posted 27th Jul 2012 at 11:02
Nitehawk10
The thing is the fans aren't coming on when they should they only come on if I disconnect the plug
Paul
Posted 27th Jul 2012 at 11:18
bellcp306td
are they coming on half speed at 95?
Posted 27th Jul 2012 at 16:18
Nitehawk10
No there not coming at all
Paul
Posted 27th Jul 2012 at 16:34
tvrfan007
Your plug is probably manky where the fan cowling plugs in, behind the rad on the right hand side.
http://www.peugeotlogic.com/workshop/wshtml/electric/ac306/coolfan2/fanop1.htm
I used that guide to diagnose mine. I only had one fan running at full speed as the 12V supply had gone awry on half speed operation which subsequently removed the left fan from the circuit completely in both operations.
Have a search on here for info, the fans can be problematic. The good thing is the HDI doesn't call for them much - i left mine for months before bothering to diagnose it as it never called for them. High speed fans are 105 iirc, literally just before the red line.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 27th Jul 2012 at 17:13
Nitehawk10
it doesnt have a plug in the rad
Paul
Posted 27th Jul 2012 at 18:14
tvrfan007
Hence why i said behind the rad..
Open your bonnet stick your head to the right of the peugeot badge and look down at the bottom passenger side corner of the radiator - then move about an inch to the right. Voila.
you got fans, you've got electrickery in there somehow. http://www.306gti6.com/forum/showthread.php?id=149363
I'm Si btw Tee hee
Posted 27th Jul 2012 at 19:16
Nitehawk10
but what iam saying is if i unplug the temperature sensor the funs will come on fast speed but if i plug temperature sensor back in and let the engine run up to the temperature of 95 the fans dont cut in i have changed the temperature sensor checked the fuses ect
Paul
Posted 27th Jul 2012 at 19:32
Nitehawk10
i think ive been l;ooking at the wrong rad i been looking at the rad cos i have AC as well
Paul
Posted 27th Jul 2012 at 20:02
Nitehawk10
what does this switch do
Paul
Posted 27th Jul 2012 at 21:12
Posted 27th Jul 2012 at 21:19
Nitehawk10
i was told to go here http://www.306gti6.com/forum/showthread.php?id=149363 what does this part do
Paul
Posted 27th Jul 2012 at 21:20
That's the plug that links the fans to the car ?
Posted 27th Jul 2012 at 21:43
Nitehawk10
iam trying to find out why there not cutting in when they should
Paul
Posted 27th Jul 2012 at 21:45
Yes we know that and as said you need to check that plug for corrosion ? It's nothing to do with rad it's attached to fan cowling ? You will need to remove the front of the car to get to the fan cowling and that plug Yes
Posted 27th Jul 2012 at 21:54
Nitehawk10
ok cool i will check that tomorrow if there corrosion there hows the best way to clean it
Paul
Posted 27th Jul 2012 at 21:56
Nitehawk10
but what i cant understand is if i disconnect the temp sensor the fans will work in default mode but as fast speed
Paul
Posted 27th Jul 2012 at 22:00
No idea not even sure you can ? Might have to wire in a replacement plug ?
Just out of interest my hdi barley gets really hot even in traffic ? My fans never kick in as the temp remains really low ? Is yours heating up quickly ?
Posted 27th Jul 2012 at 22:03
Nitehawk10
no mine doesnt heart up quick i sat in traffic for an hour and half thats how i noticed the fans didnt work they used to work but they have just stoped working
Paul
Posted 27th Jul 2012 at 22:17
That's because its a s**te system when air con is involved. You will end up changing everything and get no where Yes been there done that
I assume you aircon is not working ? If so best option is to switch the cooling system wiring to a non air con set up ? This is controlled by a thermostate switch othe rad Thumbs up
Posted 27th Jul 2012 at 22:25
Nitehawk10
how do i do that then and i dont see any other switch on the rad only the cowling
Paul
Posted 27th Jul 2012 at 22:27
