Should I use the beam or will that knacker it?
Cheers Dai
Xbox Live: DaicarvideoGuy, Forza 4
| Author | Subject: Rear Axle stand placement Help! |
daicarvideoguy
Newbie Location: Marcham Registered: 04 Apr 2011 Posts: 43 Status: Offline |
About to swap exhausts. Want the car on axle stands before I get undernithe it, but cannot see an obvious place for them to go at the back of the car.Should I use the beam or will that knacker it? Cheers Dai ________________________________________ Xbox Live: DaicarvideoGuy, Forza 4 |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
you can put them either side of the beam.But there should be sill ones as there is at the front :s ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
daicarvideoguy
Just found this thread http://www.306gti6.com/forum/showthread.php?id=146829 It didn't come up in the website search box but did with google how strange. Anyway think I have a n answer ________________________________________ Xbox Live: DaicarvideoGuy, Forza 4 |
Rear beam will be fine, it's rock solid and there's no weight at the rear of these cars anyway ![]() ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
stan_306gti6
Yep, jack up on the rear sill points and place the stands under the rear beam one each side. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Or as said there are sill points about 8" in from the rear, they have a little folded over tab on them, this would make access a little easier for you as the stands would be further apart, and more stable, which is handy when you are trying wrestle a reluctant exhaust off a car!________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
davewagon
Senior User Location: Corby / Northampton Registered: 21 Feb 2007 Posts: 889 Status: Offline |
Where do you guys jack the car from when you want to put the stands under the sill points ?________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
The beam/subframe, tripod ftw.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
Middle of beam________________________________________ |
davewagon
And what about for the front sills, where to jack then?Spread weight with plank of wood or anything? ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
Front just jack up the subframe from the mounting points and put the stands on the sill jacking points________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
davewagon wrote: And what about for the front sills, where to jack then? Spread weight with plank of wood or anything? Jack the car on the sills then put the stands between the the 2 big bolts on the sub frame job done as for the rear well that comes up with the front so jack the car up from the front then put the axel stands under the rear sill points. |
