Author Subject: Raspy!
Matt_rallye
Got a Decat and a magnex system on the rallye and it sounds really raspy around the Decat area. Is it likely to be a blow causing the rasp or is it the Decat?
Would heat wrapping it make a difference?
Posted 10th Jul 2012 at 09:05
clen666
Decats do tend to increase the 'raspy' sound of the system, probably still best to check it if you think it could be blowing though.
Apparently wrapping does quieten them down a bit
Team 'unintentional rat look'
Posted 10th Jul 2012 at 09:15
^^ This
I would get under the car and just check it whilst it's running to be sure there are no leaks but I'm guessing it's just the sound they make that you're hearing. Smile
Posted 12th Jul 2012 at 07:56
When I first got a decat in my power flow the actual decat itself let loads of noise through so you get a horrible rasping from Underneath the car. I heat wrapped the whole Down pipe all the way to the centre box and it's much improved. Had it off to change a few exhaust gaskets the other day before going supercharged and found I had some spare heatwrap after doing my manifold ages ago so I went over the top of the wrap on the decat again so now it has 2 layers. No noise from it at all now even at full boost and pops and bangs out the exhaust like a goodun Big grin
Posted 12th Jul 2012 at 12:02
argyle
Ive just done this, this morning.
mine sounds like its blowing but cannot find out where. had all joints cleaned, sealed etc but nothing changed. hoping the wrap will help!
Just gotta wait for the sealant to dry properly befor i can try it Sad
Posted 15th Jul 2012 at 17:09
Matt_rallye
It's rasps with throttle not at idle, will heat wrap it. Anything recommended?
Posted 15th Jul 2012 at 17:51
General exhaust wrap, available from places like Rally Design or Demon Tweeks. Smile
Posted 16th Jul 2012 at 19:45
Matt_rallye
Okay awesome. I'll look into it once my engine is rebuilt
Posted 16th Jul 2012 at 22:11
eBay Thumbs up
Posted 16th Jul 2012 at 22:29
