I'll add a proper description as I go along but some pic's to start with
First off how it started with a fully stripped car and mild spec engine, Steel Rods, JE Piston's, Head and some Kent cams with mere pin hole 45mm bodies
Then
Much better and allot Lighter being 50's
Engine on the stand, new spec is basically
Sanex Rods
JE Pistons
Mad Pete Head with larger inlets and flowed nicely (I hope)
Solid Lifters with Cat cams 4903272 with a huge 13.75 lift
Extra Long Inlet manfold
Renault Pico Injectors
Vibration free complete engine balance and weight matching
Omex 600 ECU with full throttle shift
And in the hole
306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements,
www.pugracing.com
miles
, what happened to that 205 then,it looked really nasty?
