displaying posts 1 to 25 of 40
Author Subject: Engine Maintenance / Which Oil / Coolent
martin
Afternoon chaps
Wondering if anyone can advise on if there are any ' idiot guides' on how to do an oil change on the GTI6? ... I reckon mines is definitely due an oil change but have never done one before.
I have been told off a mate that i should use this (http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_203587_langId_-1_categoryId_255221)
Followed by this oil - (
http://www.ebay.co.uk/itm/5-Litre-Lubricating-Oil-Total-Quartz-9000-5w-40-/160647323468?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2567539f4c) - although not sure how much oil it takes to refill the engine once drained.
From what i can gather i'm hearing a slight tap when idle so i'm hoping that its only an oil change thats needed!
Can anyone please offer any tips for a complete novice?
Thanks,
Martin
Posted 4th Jul 2012 at 13:51
Drive the car to garage, open wallet, pay mechanic to change oil and filter, drive home with nice clean hands, simples.
Posted 4th Jul 2012 at 13:54
Failing that, drive the car to get it up to normal operating temperature, jack up, support the car on axle stands, put down plenty of cardboard, find a suitable container (Something that will hold at least 5 litres of old oil) remove sump bung (19mm I think) drain oil, remove filter, you may need a filter wrench or Gorrilla grip hands, dont slip and spear the radieator! Wipe excess oil off the front of the block. Lubricate the rubber seal of new filter with a dab of clean engine oil, spinn it on and tighten firmly by hand. Replace sump bung and copper washer in the sump, fill with 5 litres (Check correct ammount, I have a poor memory) of engine oil. Drop the car back down on the ground, drive for ten minutes, allow to cool and check oil. Top up as necessary. But if you had to ask, then you probably don't have much in the way of tools, jacks, containers etc. So I refer you to my first post LOL
Posted 4th Jul 2012 at 14:00
4.5 litres it is isnt it?
Posted 4th Jul 2012 at 14:13
russbez
i wouldnt use the oil treatment stuff
just change the oil
My Rallye project thread
Posted 4th Jul 2012 at 14:32
indeed, all that stuff is just horrid chemicals that mess everything up inside your engine. Like that redex stuff.
Posted 4th Jul 2012 at 14:33
martin
cool thanks for that guys .. think i got lost after the bit ' remove sump bung ' lol ... i really am useless with a spanner.
thinking that taking it to a garage will be my easiest option .. financial constraints are a bit tight at the minute so trying to do it the cheap (by doing it myself)
anyone in or around glasgow fancy helping ! lol
what about the grade of oil is that decent enough?
Posted 4th Jul 2012 at 14:43
smegal
FAQ
http://www.306gti6.com/forum/showthread.php?id=17336&page=1
Oil filter
http://www.ebay.co.uk/itm/PEUGEOT-306-93-03-OIL-FILTER-GENUINE-1109T0-NEW-/330488889274?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf2ac3fba
Any 10W40 oil should do you
These are a godsend for getting the filter off
http://www.ebay.co.uk/itm/12-ADJUSTABLE-OIL-FILTER-PLIERS-AUTOMOTIVE-GARAGE-60MM-115MM-REMOVAL-WRENCH-/270918383989?pt=UK_Hand_Tools_Equipment&hash=item3f13fe7975
Then you will need a 8 or 9mm (I can't remember which) allen key socket or 21mm sapnner
You will also need something to drain the oil in to
Ex SC-6
Now in a Megane R26
Posted 4th Jul 2012 at 14:52
russbez
id do it if you were local Smile
Bound to be a users in glasgow that would do it for some beer money
Posted 4th Jul 2012 at 15:03
all the help you'll ever need is right here,..
we've all got to start somewhere,..
just think of them as a big meccano set Wink use the right tools for the job and you're common sense and you wont go far wrong remember where here if you get stuck with anything! Wink
Posted 4th Jul 2012 at 15:05
russbez
too true!!
Posted 4th Jul 2012 at 15:07
iplay
A jack and axle stands and a halfords professional tool set would be useful.
Jack under the front sil (notch behind small square cut out) . axle stand under the subframe (in the recess part).
Buy a black plastic Halfords Oil catcher and put some cardboard under that.
You need a crushable copper washer from pug and an oil filter.
It makes sense to change air filter (pug) at the same time.
Maybe even the gearbox oil (pug plus need a crushable washer) (buy a Halfords Orange long neck filter to refil gearbox oil through the breather plug on the top of the gearbox. 2 * 1 litre of pug gear box oil.
And plugs if they have not been done in the last 20,000 miles (Halfords do a nice plug socket)
Mobil 1 0-40 is has the most similar properties to the OEM Quartz oil but is a synthetic. It comes down to the right viscosity at low and high temps. Its not cheap but its good. Nice engine note too.
4.7 litres from total empty. 4.5 litres after a drain. 1.5 litres between botton and top of dipstick.
A bottle of Forte gas treatment in the fuel tank would also help the car run better.
Posted 4th Jul 2012 at 15:13
martin
thanks for the offer Russbez ... Inverness-shire isnt that far away (even quicker as you drive a supercharged number!) Razz
Posted 4th Jul 2012 at 16:13
Do you not have any mates capable that could supervise you of an evening?
It really is very simple and only requires following a simple list of steps.
I appreciate where you are coming from with limited knowledge - we all have to start somewhere.
Mull over the FAQ and shine a torch under your car and familiarise yourself with the sump plug, see if you have the right sized socket etc. Build up the confidence and when you have the items needed to do it crack on of a dry afternoon.
There was a lad on here who had engine problems and was worried about swapping his engine over. A few FAQ's later and some guidance and he ended up getting carried away and doing a complete overhaul from what I remember. You'll soon realise from getting under the car and looking at how to access to filter etc whether you feel confident or not.
The above is not meant to sound patronising LOL
  • Posted 4th Jul 2012 at 16:38
    "YOU CAN DOOOOO IIIITTTTT"
    Quote from many films with Adam Sandler
    Posted 4th Jul 2012 at 16:40
    smithers
    Where abouts are you?
    Should be able to give you a hand one weekend or an evening after the 30 July (working away throught the week) Thumbs up
    1997 Black GTi6
    smithers205 at hotmail.com
    Posted 4th Jul 2012 at 16:50
    martin
    I'm in the sunny east end of glasgow smithers .. and thanks for the replies chaps much appreciated.
    I do have some axles that i could put the car on which is a start but i dont really have the tools for the rest of it (mainly coz i wouldn't trust myself!)
    It's annoying as from what you guys have said .. it is a straight forward enough job .. and would be good to have the satisfication to say that i managed ut ..
    That said I'm heading off next weekend for a few days and was hoping to have the coolent / oil filters etc changed so might need to stick into a garage
    Posted 5th Jul 2012 at 11:18
    Coolant is a bit more of a pain in fairness. I can never be arsed with it.
    Box and engine oil are a piece of pee though.
    Box particullarly as theres no faffing with a filter and theres less to drain
    Posted 5th Jul 2012 at 11:21
    smithers
    Just in Dennistoun myself. Got all the tools we should need.
    Should be able to show you the ropes on Saturday if you want. Thumbs up
    1997 Black GTi6
    Posted 5th Jul 2012 at 12:51
    martin
    that would be legendary smithers .. I would pay you for the trouble as would be cheaper than going to a garage! .. What would i need to bring - for the job?
    Posted 5th Jul 2012 at 13:01
    russbez
    bought this cause im too lazy to go to local peug Whistle
    it comes with new copper squash washer
    edit : guess i should read descriptions LOL
    Posted 5th Jul 2012 at 13:02
    Oil
    Filter
    Antifreeze
    Crushable washer (Sump plug)
    Car
    Biscuits
    Posted 5th Jul 2012 at 13:03
    Im not sure on the differnence but if you cant get a TO then an AL is the new part number for the fine long lasting joby
    Posted 5th Jul 2012 at 13:38
    martin
    Not sure if i should be changing spark plugs when smithers and i are changing the oil? I had a conversion done 2 years ago and dont really cover that many miles .. so not sure if i should bother changing the plugs as they should be fairly new?
    Posted 5th Jul 2012 at 13:50
    How many miles have you done since?
  • Posted 5th Jul 2012 at 13:54
