Author Subject: Crownwheel to diff torque
mabgti
NV motors
Does anyone know the torque for these bolts?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Jun 2012 at 14:20
65nm 48lbft.
use new boots+threadlock Thumbs up
Posted 28th Jun 2012 at 14:30
mabgti
NV motors
cheers fella Thumbs up
ordered from pug, suprised they dont keep em in stock.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Jun 2012 at 15:07
I'm not, how often do people change a BE diff? LOL
Posted 28th Jun 2012 at 15:31
x2. LOL
Posted 28th Jun 2012 at 20:06
mabgti
NV motors
Now you mention it. But id presume with all these hellish modified pugs in the uk. Theyd take a stock check.lol
Atb diff FTW
AWESOME out of corners.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 29th Jun 2012 at 19:43
mabgti wrote:
Atb diff FTW
Amen to that, I love the traction mine gives. Yes
Posted 29th Jun 2012 at 20:18
Rich E Forum Admin
Why not re-use the old bolts? The specified tightening torque isn't enough to stretch them.
I re-used my existing ones when I fitted my Quaife.
Posted 29th Jun 2012 at 21:41
they have a tendency to strip the threads on removal.
Posted 29th Jun 2012 at 22:40
This is true, although I've never seen it myself, I know this can happen. Yes
Posted 30th Jun 2012 at 10:52
jeffers Forum Admin
I think it depends on how you undo them, if you just wind them out they will strip. If you just crack them all then wind them out you can get them undamaged.
Team Running Engine again!
Team Negative Camber!
Posted 30th Jun 2012 at 18:13
mabgti
NV motors
Hmmm. Mix feedback, but yes the old ones stripped on removal.
Trackday trackday trackday!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 30th Jun 2012 at 18:33
Rich E Forum Admin
Did you take them out one at a time or slacken them all gradually?
I've always slackened them gradually and never had any strip. I must have done half a dozen BE diffs now and I've never had a problem.
Posted 30th Jun 2012 at 19:15
tvrfan007
When an item is torqued up, each of the bolts should be cracked in succession prior to winding them out.
You don't put them in and torque them up one by one, so why would you do the reverse?
Both my BE diffs let the bolts come out with no issues, i cracked all then removed. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 11th Jul 2012 at 08:48
mabgti
NV motors
If the CW isnt position right and torqued right from factory then removal will always stip as the thread hits the CW off centre of bolt hole.
Anyway, i'd always use new bolts on the CW as i've seen a few come loose on various cars.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 11th Jul 2012 at 14:49
tvrfan007
Given that it's a capscrew that's used, which maintains a constant outside diameter along it's threaded and non-threaded portions - that's not actually possible, even if in service rotation occurred. It's intended use is to prevent exactly that. That's a rather large engineering faux pax, to utilise a fastener with a propensity to allow slippage and prevent dismantling! Smile
Nontheless, I also used new bolts when assembling my new diff, as Miles supplied them.
I'm Si btw Tee hee
Posted 11th Jul 2012 at 16:59
You probably could use the old bolts with no issues, providing they were undamaged on removal. Although for the cost, I would always prefer to use new ones just for peace of mind to be honest. The bolts never stripped on mine when I did it for the ATB fitting but new were used regardless. Smile
Posted 12th Jul 2012 at 07:48
