Author Subject: Locked out of Radio - fixed
iplay
I reset the ECU today and put in teh wrong radio code by mistake. Usually I get a 2nd chance to put a code in but this time I am locked out? I know the code for the radio but it is not allowing any code input atm. Its a peugeot model with a tape player.
Posted 27th Jun 2012 at 17:49
darzmat
you may have to leave it a while,
i know with ford radios when you get locked out you cant re enter for half an hour
Posted 27th Jun 2012 at 17:53
ian7675
Techno Viking
I once had an Alfa where you had to leave the stereo swithched on with the ignition on for 60 minutes LOL At the time I only did short journeys so it was weeks before I got a chance to sort it.
Less than 24 hours to go!
Posted 27th Jun 2012 at 18:47
davidmartin
IIRC you need to hold in the wave button when turning it on,don't quote me on that though ,It's been a long time. but worth a try.
pet hate, the cat
Posted 27th Jun 2012 at 20:38
iplay
Many thanks. This bypassed the code altogether ... maybe FAQ this fix?
Posted 28th Jun 2012 at 11:18
that's only a temporary fix though i think..
Posted 28th Jun 2012 at 12:17
iplay
yes correct. It has to be done every time the radio gets turned on.
is there a way to flash tem to reset without going to pug?
would a peugeot diagnostic machine be able to unlock it ? or is it radio out job?
Posted 28th Jun 2012 at 15:38
enter the code next time?
there is no diagnostic connection to the radio, its a 306 LOL:
Posted 28th Jun 2012 at 15:59
iplay
so far it is noit allowing me to enter the code? do i have to drive the car a bit or after a certain time it allows another go?
Posted 28th Jun 2012 at 16:38
mik
I went through this as the PO didn't have the code for mine. Pug offered to give me the code for £20. I said could you waive the charge and give me the code for nothing as I'm a really top bloke and everyone I know thinks so. Pug said nope, you will still need to pay £20. I said thanks but no thanks - I'd rather put that towards a more modern head unit.
Cherry Rallye SOLD
Posted 28th Jun 2012 at 17:22
Leave the ignition switched on for half an hour or then the radio will reset Yes
Posted 28th Jun 2012 at 17:52
iplay
Once again many thanks to everyone who helped out. But we have a winner here ... leaving the key in ignition on first turn switch for an hour clears the lockout. Thumbs up
and I was looking forward to sweet talking the new girl in servicing Love :whislte ... £20! Thumbs up
Posted 28th Jun 2012 at 18:00
I meant to put or leave it for an hour Yes
Posted 28th Jun 2012 at 18:22
Looks like it's had numerous entries wrong previously.
Posted 28th Jun 2012 at 21:10
iplay
I thought I had fixed this but apparently not ...
the radio works without ignition so i think i need to change the fuse over first and then do the above fix. Does anyone know the correct position for radio off without ignition?
Posted 29th Jun 2012 at 13:28
smegal
It's in the fusebox FAQ. I can't remember off hand.
Ex SC-6
Now in a Megane R26
Posted 29th Jun 2012 at 13:33
If the radio works with ignition off the fuse needs to be moved up I believe ?
If your using a phase 3 cd unit in a phase 2 car the wires will need switching over so you have power to the memory.
Ie the ignition and permenant live will be the wrong way round Yes
Posted 29th Jun 2012 at 16:42
ahhh so that's why a phase3 unit didn't work properly in my 205 when I first fitted it!! thought it was the adapter that was at fault, bas**rds LOL
Posted 29th Jun 2012 at 16:44
24 Grail
Posted 30th Jun 2012 at 00:15
iplay
I had to press the wavey button for 2 seconds to clear fault codes after leaving it an hour.
its really fixed now Thumbs up
+1's all round thanks
Posted 30th Jun 2012 at 09:41
