Author Subject: Removing rear quarter panel? Need to get to Alarm box
ben8s8
I need to get to the alarm box to disconnect it. Is the panel I need to remove the one inside the boot at the top, on the drivers side - which goes from the boot to the rear window?
If so, can anyone describe how to get it off please? There are two torx screws which Ive undone but thats as far as Ive got, it seems pretty well stuck in there
Thanks.
Posted 25th Jun 2012 at 11:16
Push the window seal off for starters then once two torx removed should just wiggle off. Seat need to be pushed forward too.
Oh that's not where it is after re reading think it's the one under the window. If so C trim needs removing as does B to get to screw underneath. Once seats out the way and pillars removed it obvious. Screw behind pocket iirc too.
Posted 25th Jun 2012 at 11:41
You taken out these screws?
Posted 25th Jun 2012 at 11:46
ben8s8
Ive taken out the screw shown in your picture and one which is by the standard cd player in the boot. I cant see anymore to remove and the panel feels pretty stuck in there...Dunno
Posted 25th Jun 2012 at 12:08
one behind the B pillar where the seatbelt panel meets it about half way up
edit> also make sure window seal and door seal are peeled back, and run a flat headed screwdriver around the edge where it is pressed against the door shut. it'll help ping it off
Posted 25th Jun 2012 at 12:09
Resistance from clips?
Have a wheetabix and get out and give it another shot.
  • Posted 25th Jun 2012 at 12:09
    ben8s8
    I need to undo this seatbelt pillar right?
    Also, '''' If so C trim needs removing as does B to get to screw underneath. Once seats out the way and pillars removed it obvious.'''' What is trim C and B? Sorry, Ive never done this kind of things before!
    Posted 25th Jun 2012 at 12:44
    yep, that comes out
    where the seatbelt (drivers front seatbelt) is, just where that panel meets the panel you are attempting to remove, there's a little torx screw under there as well
    Posted 25th Jun 2012 at 12:49
    Yes to the above.
    A pillar = trim for windscreen pillar
    B pillar = trim for seat belt/door pillar
    C pillar + trim covering rear quarter pillar from rear window to boot.
    ben8s8
    Finally got it off! Black alarm box disconnected - hopefully no more dead battery. Thanks guys.
    Posted 25th Jun 2012 at 14:07
    I'l give you a tip before someone else (almost me) gets fed up and gets offensive. LOL
    If something is ever infront of what you are trying to get to, remove it first.
    /that is all.
    PS. Was it you who invented crotchless knickers?
  • Posted 25th Jun 2012 at 14:14
    ben8s8
    Thanks for the tip dangti6. Yes it was me whom can up with the innovative design for the crotchless knickers. I hope you are appreciating them!
    Posted 25th Jun 2012 at 14:34
    Used to, but got fed up with my cock falling out all the time so just roll commando now.
  • Posted 25th Jun 2012 at 14:37
    you underestimate the versatility of the crotchless knickers. if you wear them your cock falls out, which obviously is bad. but if you wear them back to front, you can poo without taking them down, which is good
    Posted 25th Jun 2012 at 14:47
    Remember, fitting is the reverse of removal.
  • Posted 25th Jun 2012 at 14:54
    Puggie
    LOL LOL LOL LOL
    Posted 12th May 2013 at 19:07
