displaying posts 1 to 25 of 37
Author Subject: Finally back in another 6!!!
astragsi237
Woohoo Just got home from Norwich after picking up my second 6 Big grin WOW,I forgot how well they pick up speed & how great they handle.
Got a massive grin on my face from the 3 hour drive back,Picked up a Silver phase 3 for £700.Overall its pretty clean just a few niggly bits to sort out.
After some advice as one of the major problems I've got with the car is the two fans aren't kicking in to stop the engine overheating??
My friend has had a quick look,taken the 3 relays out checked them & there fine,also checked theres power going to the fans with a multi meter but they just refuse to work.We are puzzled!
Any suggestions?
Ill add some pics up tomorrow Thumbs up
Phase 1 bianca white GTi-6:SOLD
Phase 2 blaze yellow d-turbo:Off to scrap heaven
Phase 2.5 platinum silver GTi-6:Just purchased :-D
Posted 23rd Jun 2012 at 20:58
chrisd306
be a faulty temp sensor maybe? or a bitron unit fecked, try running a direct feed to the fans to see if they work, might be fecked, cant mind how a standard one is wired up again tho
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 23rd Jun 2012 at 21:04
Niall
Try unplugging the brown plug on the thermostat with the car running. Fans should come on high after a few seconds as a fail safe.
If they don't, the control unit above the horn needs replacing (common for them to go). I've got one I can sell you for £12 posted.
Posted 23rd Jun 2012 at 21:06
30ASTOR6
as above plus one! took mine out the other day it never seems to dissapoint whats on tap!!
TEAM ASTOR GTi 6
SNAP-ON SUBARU
SOON NOT TO BE TEAM DIABLO MEREDIAN (for sale)
Posted 23rd Jun 2012 at 21:11
astragsi237
Thanks guys ill give this a try first thing in the morning! Fingers crossed its a simple fix
Posted 23rd Jun 2012 at 21:14
If one of your fans has stopped working, then neither will work at half speed at 97C as they are wired in series...
As above, disconnect the brown sensor on the thermostat housing with the engine running and see which fans come on (if any).
Posted 23rd Jun 2012 at 21:26
astragsi237
I guess if neither come on when I disconnect the plug the the whole fan unit is knackered then?
Thanks for all the advice guys
Posted 23rd Jun 2012 at 21:28
aaron6
Just be sure to check that both run on half speed before the fast speed fans kick in.
Posted 23rd Jun 2012 at 22:38
astragsi237
Im bored so just been out to the car now,Unplugged the brown sensor with the engine running & the both fans still not working :-(
Posted 23rd Jun 2012 at 22:57
Most likely your bitron uunit under the passenger front wheel arch is goosed then. Yes
It could of course be that BOTH your fans are broken. To test this, put 12v direct to the fans and see if they spin up. If they do and you've already checked the relays then the bitron unit will need replacing. Smile
Posted 24th Jun 2012 at 07:27
mattgti6phase2
Try turning them by hand at the point they should come in. This happened to my mate 6. Both fans appeared dead so i let it run up to temp and gave them a nudge and they came alive. Then he bought a 2nd hand fan including cowling and it's been fine ever since.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 24th Jun 2012 at 13:12
arigti6
Wooohooo! Big grin
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 24th Jun 2012 at 14:56
6waysforward
You can take out the relays behind the grill and bypass them with a short piece of wire, if the fans still don't come on then there probably buggered.
Welcome back Smile
Posted 24th Jun 2012 at 18:40
mechanical_repairs
Also could be worth checking the 40 amp fuse.
Carl
Posted 24th Jun 2012 at 19:36
iplay
I had a fan that barely moved. Its been a problem on and off. Finally found that the lower connection plug which clips intot eh fan motor was oxidised on the aluminium pins.
Do the fans stop if the aircon pressure is too low or has a leak?
Posted 24th Jun 2012 at 19:50
Carl
That's a good shout. Yes
Posted 24th Jun 2012 at 19:58
The cooling fans are not affected by the air-con, however when you turn the air-con on the fans will come on IF there is enough gas in the system. If not, neither the air-con or the fans will come on. Wink
Posted 24th Jun 2012 at 19:59
astragsi237
Carl
Is this located inside the car? ill take a look now,if its fine ill get hold of another set of fans & control unit to be on the safe side Smile Really appreciate the help!
(edit) just looked in the manual....Off I go to check
Posted 24th Jun 2012 at 20:21
Ed_van_dijk
Who you buy it off from Norwich?
Astor 6
Posted 25th Jun 2012 at 14:39
astragsi237
A bloke called Andy about 10mins away from the town centre?
Posted 25th Jun 2012 at 18:42
pete26
Congrats dude but i sort of feel this thread is quite redundant without pictures? Sad
Ph2 Black GTI6
Ph3 China GTI6
206 xsi manstone daily runner (GAY)
Ph1 Cherry Red GTI6
307 HDi 110
Posted 26th Jun 2012 at 18:20
pieface
I have seen it on the ad he bought it from, tidy motor Thumbs up I have pics?
its not how fast you go, its how fast you stop Big grin
team diablo 6 for sale SOLD Sad looking for an ASTOR
Just got the hang of clickys clicky
Posted 26th Jun 2012 at 19:22
astragsi237
Just had another set of fans fitted yesterday but they still don't kick in,BUT I pulled the brown plug on the thermostat with the car running & both fans work on a high speed? Dunno Is this the control unit thats buggered?
Posted 17th Jul 2012 at 20:17
Bitron unit is prob shot bud
Found behind passenger wheel arch / inner wing ? Thumbs up
Posted 17th Jul 2012 at 20:32
manthos
You were down in Norwich and you didn't say!!! Would have been nice to say a quick hello
Was it off a guy called Neil??
Team SUPERCHARGED
Old Project thread
Posted 17th Jul 2012 at 20:37
