Author Subject: Rear passenger side of boot is soaking wet?
ben8s8
I looked in my boot and on the passenger side to the rear there was a massive puddle down by the passenger side rear light. Any ideas which part needs replacing for this problem? Arches or window sill...other?
Thanks.
Posted 19th Jun 2012 at 23:43
Boot seal at a guess
Posted 19th Jun 2012 at 23:56
Could also be seal on back of rear light, or the arch has rusted through.
Posted 20th Jun 2012 at 00:01
Rear light seal tends to fill lights not leak into body iirc.
Posted 20th Jun 2012 at 00:57
If it's split at the top it p**ses through the mounting holes, mine used to do it.
Posted 20th Jun 2012 at 01:10
jimmyhackers
theres a plastic cover on each side inside your boot to gain access to the rear arches if you need to undo your bumper.
mine used to pop of with air pressure i can only pressume, in my 1.4. if i went through puddle this would let a large amount of water in.
happened a few times so i got fed up and siliconed them in and they stay put ever since
Posted 20th Jun 2012 at 18:03
ben8s8
I take it that these are the things you're talking about?
Did you have to remove anything to get them in?
Posted 25th Jun 2012 at 19:17
