Author Subject: Catcams 4903110
For sale are a pair of Catcams 4903110's.
Included are 16x valve springs (PAC-S90019) and 16x spring retainers (99318).
The cams have been bedded in and covered approximately 2000 miles. I bought these second hand with the intention of building up a forged high compression lump for my track car but i've decided to go down a different route.
I paid more than they are up for, i'm in no rush to lose more money so sensible offers only please. Smile
Catcams website
Posted 30th Mar 2015 at 20:53
Bump. £475 delivered?
Posted 4th Aug 2013 at 20:10
Bump £450 delivered?
Posted 30th Mar 2015 at 20:51
http://catcams.co.uk/acatalog/4903110.pdf
full cam details here for you.
2.95mm lift @ TDC, so well over twice the safe lift for a standard piston LOL using the springs are a must at 11.50 mm lift, as the std springs co coilbound past 10.9mm
Posted 30th Mar 2015 at 21:49
edhunter
Hi,
I have a few question about the springs setup.
The recommended springs for these cams are others - double - PAC­-E92009 + PAC-­I92009
The springs that you are offering are single PAC-S90019
Also they have different parameters.
The same goes for retainers - recommended ones are 99317, and you are offering 99318.
Is it absolutely sure sure that these springs/ratianers could be used with these cams?
And is it possible to use stock (O.E.M.) inside springs with yours single springs?
Georgi
Posted 31st Mar 2015 at 13:11
To tell you the truth i'm not 100% sure about the springs and retainers, so i've emailed Catcams themselves to double check.
Looking at this page leads me to think that maybe these should work with the cams, since the top package only mentions single springs and retainers, my guess would be that the previous owner bought them like this. http://www.catcams.co.uk/acatalog/Peugeot_306_Gti-6_XU10J4RS.html
I would also assume that the retainers are to suit the single springs, and that the oem inner springs would not be used with the catcams springs.
Once Catcams get back to me i will update this thread. Smile
Posted 31st Mar 2015 at 18:53
SMITANZ
Will these be ok on stanard engine
Posted 5th Apr 2015 at 04:26
Puggitt
I'm not trying to be snobby or up myself, but seriously...
Did you actually read anything in this thread? The worst thing is you seem to be looking to mod you engine and you can't put the effort in to read the thread, how do you expect to modify your engine if you don't reasearch anything?
Posted 5th Apr 2015 at 07:14
Yes, but for a very short amount of time.
Posted 5th Apr 2015 at 14:41
SMITANZ
I was asking a question. Nothing wrong with that is there
Posted 7th Apr 2015 at 23:02
Mossy1985
Nothing wrong with askig a question bowever if you had read the post before asking (mainly number 4) then tou wouldnt of had to ask as the answer was already there
Posted 7th Apr 2015 at 23:09
