Author Subject: Climate Control
mellowr1
Hi men.
I picked the car up yesterday,Its a 1998 gti-6 on an S plate. So would that be a Phase2Dunno
Anyway,my question,when the ignition is turned to the first position i can here the fan turning and no matter where i put the blower dial it just goes all the time,allbeit slow in one position and faster in the others but on all the time.
IS THIS NORMAL??Dunno Crazy
Cheers.
Mick.Smile
Posted 15th Jun 2012 at 13:46
oddly enough i am having this issue on my 406, and i'm led to believe it's the heater fascia / panel itself that's broke
Posted 15th Jun 2012 at 13:49
If it's your controls, I have some here for sale.
  • Posted 15th Jun 2012 at 13:50
    The fans always run though dont they? I thought so anyway? Mine always have run very slowly when you turn the key, its audible as the bearings are knackered
    Posted 15th Jun 2012 at 14:12
    honestly3k
    Afaik they do turn all the time, obviously when you set your fan to off it should slow down to almost inaudible. Then get faster the higher you turn the dial.....
    Posted 15th Jun 2012 at 14:15
    darkstar753
    I thought the very same thing when I first got mine, apparently they run on very low all the time to aid circulation?
    Dont notice mine anymore since I had it out to clean the bearings as the squeak was doing my head in! the smell of grease/wd40 has nearly gone now too Smile
    Darkstar
    Posted 15th Jun 2012 at 14:40
    720puggti
    Completely normal mate. The interior blower always runs when the ignition is on, even when the control is set to "off" albeit very slowly and somewhat quietly.
    Deepak Gohil
    Posted 15th Jun 2012 at 14:43
    yeah sorry i misread that, i thought you said it was going FULL POWER all the time!
    Posted 15th Jun 2012 at 14:51
    mellowr1
    cheers for the replies. its not noisy noisy,its just i can hear it when sat in car with no engine or music on.just a tiny whirrrSmile
    thanks againThumbs up
    marc l
    both my 306's have been like this so perfectly normal. But i do think its an annoying feature and ive never seen another car that does it!
    2001 BLACK Phase 3 XS - Sold April 2010
    1999 WHITE Phase 3 GTi6 Big grin
    1991 Peugeot 205 1.6 GTi - Track Car
    Posted 15th Jun 2012 at 16:06
    could always pull the green relay out! or even rig something up to cut power to it...
    Posted 15th Jun 2012 at 16:10
    russbez
    yep my estate does this
    bit annoying
    My Rallye project thread
    Posted 15th Jun 2012 at 16:26
    daicarvideoguy
    Regard the fan been on. If the car is fitted with A/C does it automatically come on if the outside temp is above a set amount? as this week every time I fire the car up the A/C light comes on and I have to remember to turn it off as the A/C is knackered.
    Xbox Live: DaicarvideoGuy, Forza 4
    Posted 13th Aug 2012 at 19:40
    Niall
    Outside temp has no bearing on the aircon system
    On the roof console is a little grill and behind that is a temp sensor. If the temperature in the car is a certain amount higher than the temperature set at the dial, it will put the aircon on. Very annoying as my temp sensor is broken at the moment so even when I have the temp set on cold, occasionally it will come on full blast hot for a few seconds. Not what you want!
    Posted 13th Aug 2012 at 19:56
    darzmat
    its the fan next to the interior light that you hear whirring along.
    daicarvideoguy: i think it does if its pointing to the windscreen. it doesnt when its at pointing anywhere else tho, also any time you put it back to windscreen the a/c will come on again.
    Posted 13th Aug 2012 at 19:57
    Niall
    Yeah that's because aircon is great for de misting. Too many people think aircon is only for the summer but it's great in the winter too.
    Posted 13th Aug 2012 at 20:32
    mine does this also, so did my last one
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 14th Aug 2012 at 00:43
    daicarvideoguy
    Thanks chaps
    So who's A/C actually works? Mine's been buggered since I bought it. Would be nice to have working A/C in this weather.
    Posted 14th Aug 2012 at 18:19
    mines removed but didn't work anyway, there was at least one pipe that needed changing at the minimum.
    I did once Have a 306 with working aircon but it was only about 4 years old and it packed in after 6 months or so.
    Posted 14th Aug 2012 at 18:24
