Author Subject: rear brace - like on the 206GTI / RC
vts_tibi
Hi Guys,
Is there any solution to install the brace from a 206 GTI / RC (or something like that) to a 306/Xsara beam? It seems to be a good idea to brace each trailing arm, thus it would not only rely on the bearing themselves.
This is what I'm talking about:
And this was done to a 205 rallycross car:
Additionally, I found the following pic on a net of a rear brace for a 405. :
Would this make ANY kind of difference?
VTS
best 60' : 2.272
Team Trackday™
Posted 13th Jun 2012 at 20:21
mr swampy s16
**BAD SELLER**
Hmm liking the 406 brace, wonder if it works or fits the v6 couoe
Posted 13th Jun 2012 at 20:26
midlife
Another pic..
I'm sure if someone could come up with a setup like this for the 306 it would sell wellNinja
Cool
Team 330™Cool
Team "no front end or engine"
Posted 13th Jun 2012 at 20:38
vts_tibi
I think the rose jointed version like on that 205 is doable! Have to finish a DPF off on a Mazda 5 tomorrow, then I'll fire up my tape measure and imagination LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 13th Jun 2012 at 20:53
http://krs-competition.pagesperso-orange.fr/1pageang.htm
Posted 13th Jun 2012 at 21:13
If you do a solid rose jointed version you have to put the pivot in the middle of the beam like the one welsh has posted - otherwise the suspension will bind and bend/wear very quickly indeed, hence fairly soft rubber bushes on the 206 setup.
That 405 brace is a complete waste of time, not doing anything there.
Posted 14th Jun 2012 at 00:34
vts_tibi
This is good, but it needs the beam to be modified, and I'm looking for a simple solution which could be done even with the original beam Smile
Do you mean, that the fixing point of the rose jont should right in the middle of the beam tube - near where the ARB sits. OR should it be right in the car's midline?
Is the solution they did on that 205 not any good at all?
And about the 405 brace - I was thinking the same really. That company seems to love putting unnecessary weight onto customer's cars:
the best one:
LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 14th Jun 2012 at 07:21
?? how does that white one not ruin the exhaust on a bump?
Posted 14th Jun 2012 at 09:21
They're a right set of fkn numpties!
The one I looked at for Matt's clio was just as good - it bolted to some tinfoil brackets in the boot - nowhere near anything structural or load bearing, basically the only thing it would stop your shopping hitting the seats.
Posted 14th Jun 2012 at 13:05
They've made it handle like a Golf LOL
Posted 14th Jun 2012 at 13:36
Tibi - you'd need the pivot of the brace arms to be the centre of the beam, same as the trailing arm pins, otherwise they'll bind against each other.
Posted 14th Jun 2012 at 14:14
vts_tibi
is that the reason why 206 has so soft bushes at the rear bracing?
VTS
best 60' : 2.272
Team Trackday™
Posted 15th Jun 2012 at 07:52
I'd imagine so, you can use it to your advantage a bit, and have no tension/compression there in droop - then have link and bush progressively go into compression the more load there is on the arm.
Posted 15th Jun 2012 at 10:48
vts_tibi
so the best would be to mount the inner rose joints on bushes?
VTS
best 60' : 2.272
Team Trackday™
Posted 15th Jun 2012 at 11:31
mabgti
NV motors
Balerbm is working on something.. Pm him.. That last brace looks like something phillip can come up with?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 16th Jul 2012 at 03:12
dum-dum
The 206 GTi 180 stuff is available from pug and could be adapted.
The 2 parts to wrap around the beam are £80
The 2 trailing arm brackets are £70
the 2 bars are £145
total is about £300 with bolts.
Bianca GTi6 on Gold wheels. Let the haters hate.
Posted 17th Jul 2012 at 00:04
it wont work straight on a 205/309/306 beam due to the location of the torsion bars
Posted 17th Jul 2012 at 08:11
