Author Subject: Hard to select 1st gear?
gti6aus
Drained and filled the gearbox today with fresh pug oil. Thought that would solve my issue.
Sometimes you have to push the gear lever quite hard to get it into first and other times it flows into first easily.
Any ideas. Something could be worn? Linkages?
Apart from that, the gearbox is great.
1998 GTi6 Bianca White
Posted 9th Jun 2012 at 09:36
My 205 was a bugger to get first. Sometimes it would take a good push and them go past the point of selecting and have a bit of slop. Once I pushed it so hard it popped off the linkage and left me in second LOL.
I found it worse when going down in to first, took more force then.
I replaced my linkages for group N ones with retaining clips and it made the world of difference.
Might be worth popping them off and greasing up.
  • Posted 9th Jun 2012 at 09:44
    probably a worn synchro or tired spring clip, try lifting the clutch whilst in neutral then trying 1st.
    Posted 9th Jun 2012 at 09:53
    Niall
    I had this on my old 1.8. New linkages helped but it turned out to be a partially seized release arm. Unseized and felt like a new car!
    Posted 9th Jun 2012 at 09:59
    Grease the linkages, and as said try double de-clutchng.
    If that works, you've got internal gearbox wear. Wink
    Posted 9th Jun 2012 at 11:22
    heliosphan
    I remember an old episode of 5th gear where Tiff is driving a Lambo around the Anglesey circuit: he has to select 1st for one of the tight corners because of the tall gearing of the car's gearbox. So he's pushing the lever into the 1st position at (probably) around 40/50 mph. Shock
    And it's fine with it!
    I'm lucky if mine 'slots' in, rolling at 5mph! Heaven forbid if it's January and I've just started the car... 1st only when stationary or use 2nd if rolling even slightly. LOL
    Posted 9th Jun 2012 at 11:39
    I don't use my car in the winter, it sits locked up in the garage so I don't know what a '6' gearbox feels like stone cold on a winter's morning...but I'd imagine it would be a bit tight. Yes
    Posted 9th Jun 2012 at 13:04
    stilly
    you dont use your car in the bloody summer either.....LOL
    deaf in 1 eye blind in 1 ear Crazy......
    307 136bhp daily drive.....
    306 rallye stripped out and charged.....
    lee_gti6 also known as "the tit".....
    stan_306gti6 also known as "stan the dick".......
    Posted 9th Jun 2012 at 13:19
    This is true at the moment. LOL
    Posted 9th Jun 2012 at 13:47
