displaying posts 51 to 73 of 73
Pages (3): 1 2 [3]
Author Subject: Oil and Stop light on when hot but only on idle ??? SORTED
Post #51
If you have got no m8's etc in a garage with a mechanical gauge to help you out just book it in at a local garage for a check ASAPThumbs up
This will 100% tell you if you have got an expensive bill/rebuild on the wayThumbs down
Could also be the oil pick up in the sump blockedWink
If someone has used too much sealant somewhere on the eng(sump,cam carriers,cam covers etc)the excess can get in the sump then get sucked into the oil pick upThumbs down
Posted 12th Jun 2012 at 21:29
Post #52
heidi6 wrote:
This is normally a sign of engine wear in the bearings/pump especially as you have changed oil/sensors etc.
Putting an oil cooler on will cause a small drop in pressure due to the extra work for the pump but shouldn't bring on the low pressure switch. What is the low pressure rating on the switches for these engines, 1bar?, 1/2bar?
Get a pressure check done for piece of mind.
Oil temp would go through the roof if there was a presure problem ? No ?
heidi6
Post #53
bigbadbowen wrote:
Was doing it before oil cooler went on but after the pulley change ?
Hmm Strange one...
I live work (to pay) for the 306
Phase 3 Astor. Built on Wednesday, 12th April 2000 in France.
Years of 'Creative Maintenance' mean this car is now much lighter and slightly more 'race' specced... Tee hee
Posted 12th Jun 2012 at 21:30
heidi6
Post #54
Not neccessarily. When the big ends go then yes but if everything is worn slightly then it may run a tad hotter but not overly hot (unless you rag it some)
Posted 12th Jun 2012 at 21:33
Post #55
heidi6 wrote:
Hmm Strange one...
Yup indeed, the light went out as soon as the throttle moves ? And to be fair after a drive it had stopped doing it even at idle ?
Could be a gremlin in the system seeing as I have had everything unplugged etc ? And these are French electrics LOL
Posted 12th Jun 2012 at 21:34
ryangti6
Post #56
Could it be something to do with charging?
I'm wondering if you may be seeing ignition light's flickering.
Have you tried what I said unplugging the sensor?
Ryan
heidi6
Post #57
bigbadbowen wrote:
heidi6 wrote:
Hmm Strange one...
Yeah, true. It is frenchLOL
Posted 12th Jun 2012 at 21:37
Post #58
But it's only done it since I have changed a few things ? If it had just come on without me fecking about with anything then I would be a little more worried Yes
Post #59
Battery light would come on as well though ?
Posted 12th Jun 2012 at 21:39
Post #60
I'll take it out tomorrow night and tear the arse off it see what happens ? Big grin
Posted 12th Jun 2012 at 21:41
ryangti6
Post #61
Should do yes but as said, French electrics... It was the only other thing I could think of Tbh.
Ryan
Post #62
naah, its 1 bar Stan Smile
Fair enough, I stand corrected. Smile
Posted 12th Jun 2012 at 22:00
milkyb
Post #63
Said the man in the orthopaedic shoes..
Posted 12th Jun 2012 at 22:07
Post #64
Ok so took the car for a spin tonight on my private road Whistle Ripped through the gers getting up to 120 - 130 mph , oil stayed around 90 even with giving it plenty of large (cooler doing its joCool water stayed at 80 to 90.
Fecking lights still flickering a little on tick over and between gear changes if revs drop down to under a grand ?
I'm stumped ? I'll get the presure checked but pretty sure it's something to do with the pulley ?
Dunno
Posted 13th Jun 2012 at 21:33
Post #65
Definitely get the pressure checked out Chris, this will tell you so much more about what the actual issue could be, I must admit it doesn't sound too serious if you've been doing that with it. Smile
Posted 13th Jun 2012 at 22:09
Post #66
well the track has finished it off ? Starter motor won't fire and engine tapping
Posted 17th Jun 2012 at 11:54
Post #67
Engine tapping will be down to lack of oil/oil pressure. Is is definitely tapping and not knocking?
Posted 17th Jun 2012 at 12:32
Post #68
sounds top end to me ? Can't start it though as starter has packed in
Posted 17th Jun 2012 at 13:24
heidi6
Post #69
Does it tap worse under load or on trailing throttle? Have a look at your oil under a really bright (cree led if you have one) torch. Can you see sparkly bits? If yes its expensiveThumbs down
Posted 17th Jun 2012 at 17:53
Post #70
Was this done today on track at FCS Chris?? Unsure
Posted 17th Jun 2012 at 19:22
Post #71
Indeed but it seems fine all the way home all be it with a dodgy starter motor. I think there is a funny lifter as it taps for a few seconds after each time it gets started ? Then it goes away? Defo no bottom end knock. Did a few laps of the track before the brakes went off - I was mostly in the way of everything else as everyone seemed to fully track spec except me Sad
Plus my rear beam ain't great and road tyres are just balls on track Yes arse end was all over the place and needs sorting out Yes
Just not sure I can be arsed to go through the whole job of track specking a car again + the expense No
Posted 17th Jun 2012 at 21:25
Post #72
Sorted the problem now switcho engines no the problem has gone happy days Yes
Posted 8th Sep 2012 at 22:11
Post #73
Deffo a problem with the lump then and not electrically related. Glad you've managed to sort it Chris. Smile
Posted 9th Sep 2012 at 08:06
Pages (3): 1 2 [3]
